Stator problems??
Old Apr 10, 2007 | 08:29 PM
igeorgei's Avatar
igeorgei
Cool Stator problems??
Need some confirmation please.
My bike stopped charging so I just assumed it was my regulator since this is a common problem with VTR's.
I did the R1 regulator mod and the bike still wasn't charging so I did what I should have done first......checked the shop manual !!!!
I checked for resistance between the 3 stator wires at the regulator and found the resistances to be within shop manual spec between the 3 stator wires.
Then I checked the resistance between each of the 3 stator wires and battery GROUND and found that all 3 wires were shorted to ground.
My question is......according to the shop manual, the 3 stator wires should NOT be shorted to ground at all. This is an indication that the stator is shot!
Before I go out and buy an expensive new stator, can anybody confirm that my stator is probably cooked?
Thanks
George
Old Apr 10, 2007 | 08:39 PM
nineighthawk's Avatar
nineighthawk
Your stator is fried.
Lemme find this link I used to confirm when mine failed.
Old Apr 10, 2007 | 08:43 PM
nineighthawk
http://www.electrosport.com/electros...t_finding.html
Excellent flow chart.. It will remove any doubts.
Old Apr 10, 2007 | 08:52 PM
Thumper's Avatar
There is a shop in Birmingham, Alabama that does top notch rewinds and dang quick turnaround. If he has a rotor or stator like yours already rewound he just send out the replacement the same day he receives your.
He did both of my CB750F's Stator/Rotor combo in better than new condition. He even included a new wiring harness with the stator.
http://www.customrewind.com/
Old Apr 11, 2007 | 12:16 AM
igeorgei's Avatar
igeorgei
Talking thanks
Thanks for the posts guys.
That flow chart was awesome, I will archiving that one for ever...
I'll prob try to find someone local to rebuild and see how much that costs. If it's too much then I will go new.
Thanks again guys.
Old Apr 17, 2007 | 08:07 PM
igeorgei's Avatar
igeorgei
Yep
I got the Stator cover off today. She's burnt and the epoxy melted in one spot. Gonna replace it with one from Motovan. The OEM Honda stator is $390 from the dealer......ouch!
Anto
Sep 1, 2007 04:07 PM
Blurr
Apr 24, 2007 01:05 PM
Blurr
Apr 21, 2007 07:22 PM
nineighthawk
Sep 14, 2006 10:01 PM
Rollingalong
May 5, 2006 03:04 PM
