Starter Motor Swap
Old Feb 5, 2014 | 12:48 PM
2wheelsagain's Avatar
From: Victoria, Australia (Bottom south east corner)
2wheelsagain is on a distinguished road
Starter Motor Swap
Yesterday I went to start Scarlett and she cranked 1 revolution and stopped. Battery is good. Checked as many connections as I could without a teardown and all seemed ok. No joy with a jump start just lots of solenoid clicking and warm starter cable.
After much swearing I tapped the starter with a hammer and hit the button and she bellowed into life.
So, apparently some other Honda starters fit. Which ones? Straight swap or does the mount have to be swapped as well?
Old Feb 5, 2014 | 01:29 PM
If you look at any fiche you can find the Honda part number for the starter. Using that you can reverse part search which bikes it's used on:
Starter:
31200-MAT-003
Where used:
http://www.hondapartshouse.com/oempa...nda_motorcycle
The starter for those will work as direct bolt on, or you can just search e-bay for the part number.
Old Feb 5, 2014 | 01:50 PM
Wicky's Avatar
Check Hornets, CBRs - basically any 600cc+ Honda from late 90s/early 00s
Old Feb 6, 2014 | 02:20 AM
You can also rebuild your starter. eBay has rebuild kits Click here.
I had an electrical issue with my bike, and one of the things I tried was taking the starter apart and cleaning it. Although, a rebuild would've been just the same. Here's the thread click here. Post #12 has the pictures of the starter apart. It is really simple. Plus, since it was apart, I cleaned everything and painted it. It still looks fantastic today. Don't bother reading the whole thread. At the end, I replaced the entire wire harness and fixed it (I think it was a ground issue)
kenmoore
Jun 17, 2014 03:55 PM
vtrktm
May 16, 2012 01:04 PM
jay956
Oct 8, 2011 11:15 AM
nick.p0306
Jan 15, 2011 08:38 PM
Hawkrider
Sep 6, 2007 03:46 PM
