sprocket gearing
sprocket gearing
I have a 1998 superhawk with 16,000 the carbs have been jetted with a dyno jet stage one kit K&N air filter and a set of D&D slip ons I wanted to go down one tooth in the front or make it easer to wheelie but i still want top end and make it streetable what should i go with some one told be down one in the front will be perfect
Well, there is a consensus around here that -1 on the front sprocket is better than stock. Some consider it optimal.
Give it a try. You'll probably like it.
Then get rid of that K&N filter.
duran
Aug 27, 2007 07:57 AM
