Speedometer U/S
Old Sep 2, 2011 | 10:13 AM
Furrybiker's Avatar
Furrybiker is on a distinguished road
Speedo not working
Suddenly lost the speedo, the mileage counter shows but does not work.
As the sensor is £140 does anyone know if this likely to be the sensor or the clock itself? There is power in all the right places, but I dont want to spend hundreds of pounds on a wild goose chase!
Old Sep 2, 2011 | 03:17 PM
Check wiring and fuses first.
Old Sep 2, 2011 | 03:20 PM
saige's Avatar
the boss
+1 on that,had the same thing happen,just was fuse.
down the road,still had little bugs in the system,might be good to clean all wiring ends and such to get a good clean contact.
Old Sep 2, 2011 | 03:39 PM
Furrybiker's Avatar
Thanks have tried this and all seems good, fuse replaced. Mechanic also looked and still no further. Wonder if it could be the gauge itself, is there a way of checking it out?
Old Sep 2, 2011 | 04:14 PM
saige's Avatar
the boss
i would say take the speedo off and check wiring,could be rusty,bad connection or maybe wire/wires fell apart from rusting.start from speedo and work from there.
Old Sep 2, 2011 | 04:42 PM
Well as with any VTR electrical issue, the first step would be to first check and clean all the ground connections. Second would be check the all the plug connectors are clean and fully seated.
Then start checking components.
Old Sep 5, 2011 | 01:39 AM
Furrybiker's Avatar
According to the UK VTR site and the bike breakers I tried the sensor seems to be a weak point, so having tried the connections, I ordered one from a breaker for £35, just hope its not a dud.......
Very annoying that you guys pay so much less for them (Ron Ayers $61) UK £140
Old Sep 6, 2011 | 07:09 AM
Furrybiker's Avatar
Well two helpings of good news!!
Firstly the rather sad looking sensor arrived, was fitted to the bike and it worked..
Secondly even after all the time taken trying to trace the fault they said "Have it as a freebie"!
OK I have been using these guys for 30 years but still nice..
happytrack44
Oct 27, 2007 05:26 AM
wardo996
Mar 21, 2007 10:20 AM
roisman
Feb 9, 2007 06:55 PM
98VTR
Jun 16, 2006 11:42 AM
swordfish
Sep 23, 2005 03:48 PM
