Speedometer Trouble
Old Apr 8, 2009 | 05:54 PM
syf's Avatar
syf
syf is on a distinguished road
Speedometer Trouble
I've been having some issues with my speedometer. Replaced the R/R with an aftermarket unit from ebay, but still no speedo. Just checked all the connections with no luck. According to my manual the speedometer sensor could be the culprit. Any advice?
Thanks!
Old Apr 8, 2009 | 09:56 PM
shayne's Avatar
Have you checked all fuses?
Have you done the checks as per the manual to test it?
Old Apr 9, 2009 | 01:36 PM
syf's Avatar
syf
All fuses are good. I went through all of the checks in the manual to test it. I wasn't getting the 0-5V by spinning the rear wheel, which leads me to believe it is a faulty speed sensor.
Old Apr 10, 2009 | 01:07 AM
shayne's Avatar
I have never heard of one of these failing, but of course it is possible. If the test shows it is faulty, then it looks likely to be your cause. Especially if other parts of the dash still work.
Old Apr 16, 2009 | 03:13 PM
syf's Avatar
syf
The sensor looks a bit beaten up where the wires meet the sensing unit. My guess is the signal is not making it through the worn wiring. Everything on the dash works except the speedo and odometer. I will update once I get a new unit on the bike.
Thanks for your help!
Old Apr 18, 2009 | 01:11 AM
loserbaby's Avatar
jet wrench
loserbaby is on a distinguished road
I have one for you... spare motor with known good speedo sensor... as good as the hawk speedo sensor is, anyway. PM me...
I want a sixpack and shipping, I'm at 95632... we'll discuss.
LB
Old Apr 22, 2009 | 10:38 PM
loserbaby's Avatar
jet wrench
LB
Here's pics...
Attached Thumbnails Speedometer Trouble-shawk-speedo-sensor-detail.jpg   Speedometer Trouble-shawk-speedo-sensor-plug.jpg   Speedometer Trouble-shawk-old-motor-detail.jpg
Old May 8, 2009 | 08:09 PM
syf's Avatar
syf
Speedo fixed! Bought a speedo sensor (with wire harness) from loserbaby, which solved the problem. I highly recommend buying from loserbaby if he has something you need.
happytrack44
Oct 27, 2007 05:26 AM
wardo996
Mar 21, 2007 10:20 AM
roisman
Feb 9, 2007 06:55 PM
98VTR
Jun 16, 2006 11:42 AM
swordfish
Sep 23, 2005 03:48 PM
