speedometer swap
Old May 13, 2010 | 04:58 PM
alientestsubject's Avatar
Fading Fast
alientestsubject is on a distinguished road
speedometer swap
has anyone swaped out the speedometer on an 03,04,05 superhawk? I dont think i need to say why im asking......
Old May 13, 2010 | 05:30 PM
ttocsmai's Avatar
if you did a search, you would have found that information. Try the search first.
https://www.superhawkforum.com/forum...dometer+change
Old May 13, 2010 | 11:44 PM
https://www.superhawkforum.com/forum...earchid=593948
Several more... Not only to never VTR clusters, RC51 & CBR clusters works as well...
Old May 14, 2010 | 09:08 AM
Fading Fast
Im a newbie, i know i can search for just about anything. but i would also like to get some personal feedback and suggestions. isn’t that what forums are set up for? bear with me on this, its all about the community to me.....
Old May 14, 2010 | 09:30 AM
Well... I'm not busting your ***** here... Or atleast trying not to... But there is a difference between "has anyone swaped out the speedometer on an 03,04,05 superhawk? I dont think i need to say why im asking...... "
And "Hey guy's, what kind of gauge swap would you recommend, what are their different pro's and con's? I have read that it's possible to do CBR gauges and RC51 gauges, and there are numerous aftermarket gauges"
But, lets try it again... You did ask the second one right? (I'm getting old and senile, so bear with me...)
If you did, I will answear that the obviuous advantage of any DIY project over an aftermarket is the pride of having done it yourself, plus in most cases cost as a used gauge and some various small parts usualy is considerably cheaper than buying a complete aftermarket setup...
Since I'm guessing (your first post was a bit unclear on this) you have an older model VTR and want to swap in the newer gen? The speedo is a bit annoying on those as far as I'm concerned, with it beaing in an odd place and in an odd angle... But if you like it, the swap is easy... yuryur has made a fairly comprehensive manual...
I choose the CBR1000RR gauge, and apart from a mildly inaccurate temp sensor (which I think I have an easy solution for, I'll report in a while) that gauge is doing exactly what I want it too... The obvious downside of this is that the revcounter is a bit loongish, with the red in the wrong place... The easy fix is the set the shiftlight to go off at the redline of the stock speedo... All the CBR's have the temp gauge problem regarless of age 600F4i-600RR & 929-954-1000... The RC51 on the other hand uses the same resistance values as the VTR, so that's basicly plug and play...
Old May 14, 2010 | 10:36 AM
Stevebis1's Avatar
+1
But I am readind it a bit differently. I'm guessing he has a newer VTR and he doesn't like the small illegible speedo.
In any case details and delivery will help
Old May 14, 2010 | 11:54 AM
Fading Fast
+1
Thats what i was talking about, the numbers are real small and the needle barely moves. i will pick my questions better and be more to the point. i guess thats why im a squid!
Old May 14, 2010 | 12:11 PM
Nah... Don't mind me... I have two default modes... I make fun of people (see above) Or I'm grumpy... So pick your poison...
So, I'm guessing the old type of gauges isn't an option, since they have several other flaws... So what types do you like?
The 1000RR gauges have a big tacho that really moves about...
And the digital speedo is reasonably big... The only thing it doesn't have is a fuelgauge but that can be fixed...
Old May 14, 2010 | 01:03 PM
mdbuehler's Avatar
mdbuehler
[QUOTE=Tweety;265819]
I choose the CBR1000RR gauge, and apart from a mildly inaccurate temp sensor (which I think I have an easy solution for, I'll report in a while) that gauge is doing exactly what I want it too... The obvious downside of this is that the revcounter is a bit loongish, with the red in the wrong place... QUOTE]
Go on... Waiting to hear this part!!
Yeah, the tach can be decieving if you forget about it. I have wrapped her out a bit more then I intended on a few occassions before I remember the "top" is further down the gauge
Old May 14, 2010 | 01:15 PM
Um... Give me a few days to test things and I'll fill you in...
Old Jul 28, 2010 | 07:26 AM
heng47's Avatar
heng47 is on a distinguished road
Don't mind if I bump this up. Tweety, did you ever get the temp gauge to work?
happytrack44
Oct 27, 2007 05:26 AM
wardo996
Mar 21, 2007 10:20 AM
roisman
Feb 9, 2007 06:55 PM
98VTR
Jun 16, 2006 11:42 AM
swordfish
Sep 23, 2005 03:48 PM
