spark plug wrestling
Old Oct 21, 2012 | 10:20 AM
twist's Avatar
I have one for you long time hawk pilots, how in God's name do you change the front spark plug and torque it properly? My experience changing the front plug was a pain in the ***. Most plug changes are and should be a snap! I could get the front plug out and a new one in but tightening it and torquing it was a challenge. My extensions are either too long or too short. Is there a plug socket that will make this simple task a bit less of a PITA?
Old Oct 21, 2012 | 11:06 AM
Wicky's Avatar
Should be a specific deep thin-walled plug socket in the Honda toolkit with the bike - Still needs a couple of extension bars to get at through the front forks!
http://www.ronayers.com/Fiche/TypeID...73/Group/TOOLS
Old Oct 21, 2012 | 11:10 AM
saige's Avatar
the boss
its hard to get a torque wrench of any kind in there.just turn until it wont turn no more,than a light snug.thats what i do,and its not bad at all.never had a problem.
Old Oct 21, 2012 | 12:14 PM
HRCA#1's Avatar
I am admittedly old school but I simply turn them by hand till snug then give them @ 1/4 turn more, been doing this for 45 years never had a problem yet.
Old Oct 21, 2012 | 12:21 PM
Jack Flash's Avatar
Well take off, eh.
Unscrewing oil rad helps, two or three long extensions and a u-joint will do the job perfectly. As saige & hrca said, once snug, just another 1/8 to tighten it, and voilà, you're done.
Old Oct 21, 2012 | 02:51 PM
VTArrrgh!'s Avatar
The Pirate Sportbiker
VTArrrgh! is on a distinguished road
As has been said, hand tighten the thing and then turn it another 1/8 to 1/4 turn. You only need to torque a spark plug when you reinstall it (if you've removed it to do your valves, for example). I believe I was able to get at mine with two short extensions. A standard long was too long and one short was too short. Also, if I remember right, the front fender was the culprit for me. Or maybe it was that little panel under the headlight...
Old Oct 21, 2012 | 06:43 PM
twist's Avatar
you guys make me feel better. I discovered I didn't have the proper plug socket so I used the one in the tool kit. I used a combination of extensions and ratchet with a strange bend and u joint to get it. I did get it torqued. I think the torque setting is only 10 ft lbs so it's hardly worth it. Thanks for the replies and information, tighten the old school way. 1/8 to 1/4 turn after tight. Yes simple.
Old Nov 14, 2012 | 12:59 AM
Patton303's Avatar
Patton303 is on a distinguished road
Check it out man! I recently got that new Kobalt socket wrench where you just twist the handle like a throttle and attached it to the tool kit spark plug socket with an extension and it worked like a charm. So much easier. It has a sprung torque reciprocator for power. I use that wrench for everything now. I got the air box cover off with a phillips adaptor and barely lifted the tank to do it. Go get one at Lowe's.
8541Hawk
Mar 28, 2013 08:28 PM
nnjhawk02
Feb 25, 2013 05:23 PM
seattlesucks
Jul 26, 2007 06:48 PM
ATLSHawk98
Dec 21, 2006 09:32 AM
motojoe
Oct 3, 2005 04:19 PM
