Spark Plug Removal
Spark Plug Removal
I just recently bought a 1998 vtr1000 superhawk and i need to replace the spark plugs.
Two questions, how much do i need to take off the bike to get to the front plug and is there a special tool that honda sells to get into the socket well because my deep wells outer diameter was too thick.
You have to take the plug boot off. There is a spark plug tool in the bike's tool kit if you have the kit.
I think they made it easy to remove the front plug so you can use a bore scope to check for piston damage when the MCCT fails.
There are a few threads about this if you search. I think one of the sockets that fit through the cylinder is a craftsman. But don't take my word for it, I may be wrong.
As for the front, you don't need to remove anything unless you are not all that well equiped. If you have a few extensions, and a u-joint you'll be able to reach the plug. The rear, gas tank needs to go.
Welome to the forum.
I'd like to see you remove a spark plug without removing the boot, Jack.
https://www.superhawkforum.com/forum...ed-help-32399/
https://www.superhawkforum.com/forum...cket-me-32234/
https://www.superhawkforum.com/forum...uestion-29969/
the Tool kit one does of course, and a very thin wall deep well socket will.
I use a Gear Wrench 18mm chrome deep 3/8 drive socket to remove the plugs fits in no problem. Also I use a long extension with a swivel for the front plug so nothing has to be moved out of the way.
