So, what's next?
Old Apr 7, 2011 | 06:25 PM
98ILVTR's Avatar
So, what's next?
When putting my cylinder cover back on tonight, I over tightened one of those nice 10mm bolts, and snapped it right off. So, now I have a piece of that bolt stuck in my cylinder. Do I need to remove the engine now? What in the hell should I do?
Old Apr 7, 2011 | 06:36 PM
superh1998's Avatar
I did that once. Luckily I was able to use an extractor bit to get it out.
Just make sure you hit the center of the bolt if you try that method.
Then I bought a torque wrench...haha.
Old Apr 7, 2011 | 06:49 PM
98ILVTR's Avatar
It happens to be my front cylinder too, top right bolt.
Old Apr 7, 2011 | 07:08 PM
superh1998's Avatar
That definitely makes it more of a challenge.
I was lucky enough for it to be my rear cylinder.
Unfortunately, you probably can't fit a drill in there?
Old Apr 7, 2011 | 07:18 PM
autoteach's Avatar
Do you mean 6mm bolt that has a 10mm head, as in the Valve cover (shoulder) bolt? If it snapped below the shoulder, you should be able to remove it with a pick just by trying to turn it. The way the shear leaves a step that you can push on. Either that or get a left hand drill bit on it, it should walk right out.
Old Apr 7, 2011 | 07:31 PM
98ILVTR's Avatar
Yep, thats the one. It snapped on the threads. A pick sounds like a VERY long process, but I'll give it a go. I won't get to work on the bike till *maybe* Sunday.
Old Apr 7, 2011 | 07:47 PM
Ouch. I did that exact same thing, fortunately mine was out of the frame. A pick as autoteach suggested worked for me, I was surprised. Your space will limit you, but I was able to back it out a mm or two out of the head, then use a dremel to cut a flat head into it and use a screw driver on the rest.
dpenix76
Sep 7, 2007 09:12 PM
Edwards07
Sep 6, 2007 02:12 PM
nfbzike
Apr 17, 2006 06:42 PM
chickenstrip
Dec 13, 2005 06:58 PM
mrjakeanderson
May 25, 2005 09:05 PM
