So, what's next?
So, what's next?
When putting my cylinder cover back on tonight, I over tightened one of those nice 10mm bolts, and snapped it right off. So, now I have a piece of that bolt stuck in my cylinder. Do I need to remove the engine now? What in the hell should I do?
Do you mean 6mm bolt that has a 10mm head, as in the Valve cover (shoulder) bolt? If it snapped below the shoulder, you should be able to remove it with a pick just by trying to turn it. The way the shear leaves a step that you can push on. Either that or get a left hand drill bit on it, it should walk right out.
Ouch. I did that exact same thing, fortunately mine was out of the frame. A pick as autoteach suggested worked for me, I was surprised. Your space will limit you, but I was able to back it out a mm or two out of the head, then use a dremel to cut a flat head into it and use a screw driver on the rest.
dpenix76
Sep 7, 2007 09:12 PM
nfbzike
Apr 17, 2006 06:42 PM
mrjakeanderson
May 25, 2005 09:05 PM
