SH has high idle - any ideas?
Old Nov 21, 2013 | 08:05 AM
Skidmarkart's Avatar
Skidmarkart is on a distinguished road
So, my SH runs great, does everything well. I love it. It has one problem though.
When I purchased it, it had PMS (Parked Motorcycle Syndrome). I got the carbs cleaned, and replaced all fluids filters etc. She ran great. When I got her back from the shop, the idle was about 1200rpm. Since summer it has slowly been creeping higher and higher. Now, it is almost 2000rpm after she is warm. It is almost like the choke is out, but the cable is fully closed.
I am fairly handy, but no mechanical genius. Just wondering if there's anything I can try to do before returning her to my mechanic. I don't want to screw up anything. Thanks for any advice.
Old Nov 21, 2013 | 08:30 AM
Jack Flash's Avatar
Well take off, eh.
Begin with the basics. Bring idle back down, and see he she runs. You may also want to check that choke cable again, may be stuck open. Also, throttle cable. Check your throttle to be be sure returns correctly.
There may be more to this then meets the eye. If syptoms persist, I would
dig back into the carbs, and refresh them again. Bike shop may have said they did them, and just sprayed carb cleaner into them.
Old Nov 21, 2013 | 08:53 AM
CrankenFine's Avatar
+1 on Jack Flash's opinion.
Also if you don't know where the idle adjuster is the complete shop manual is posted in the technical section as pdf.
Old Nov 21, 2013 | 09:39 AM
Awesome... thanks guys. Should I initially go right to see how many turns out each screw is, then left to back them back them back out to a lower setting? Say, go in three and a half and back them out three?
Old Nov 21, 2013 | 10:00 AM
There's only one idle screw and it's a thumb screw... inside the right triangle of your bike. Just back it out until the idle is correct and go from there. No reason to count turns or anything as it is not a mixture setting or anything.
Old Nov 21, 2013 | 10:14 AM
Oh nice! An idle screw!
I looked around and couldn't see one anywhere, I though the adjustment might be the pilot jet screw on the carb. That will make my life easier... and also make me feel dumb for not being able to find it. I think I just went full retard...
Old Nov 21, 2013 | 10:20 AM
thedeatons
Jun 21, 2015 09:11 PM
saxman
Jan 29, 2007 06:14 AM
azhawk1
Dec 23, 2006 10:22 AM
DaxMiddler
Apr 28, 2006 03:22 AM
