Runs terrible
Old Oct 30, 2020 | 08:01 PM
tosainu1's Avatar
tosainu1 is on a distinguished road
Runs terrible
I’m having issues with my bike where it acts like it wants to stall after 15-30 minutes of riding. This video shows it hesitating to rev up like the carbs are messed up.. any ideas what could cause these issues??
Old Oct 31, 2020 | 08:53 AM
Need a little more history of the bike.
Old Oct 31, 2020 | 02:27 PM
tosainu1's Avatar
Bike history
The bike was supposed to be the lowest miles Superhawk in the country at 3,200 miles. It has a very low 4 digit serial number with a date of manufacture of 3/97. It doesn’t have a scratch on it. I test rode it home from Va to MD and after a while it starts to act like it runs out of fuel, or running on one cylinder and bucking like a bronco. The clutch had been replaced, tires as well as slip on delkevic exhausts. It ran just as poorly with the factory exhaust. The choke doesn’t want to stay out when you pull it. It also takes a very long time to get up to operating temperature and idles low. The revs hesitate when you give it a hand full of throttle. Those are some of the symptoms. It seems to be a fuel or carburetor issue...Those are the symptoms and any help is much obliged.
Old Oct 31, 2020 | 02:44 PM
YMRacing's Avatar
Start simple. Fuel tank vent. Choke at that age probably needs replaced. Friction keeps it open. They are cold blooded. Mine is, even with the upgrades to the carb etc. Idle can be set simply. Is the hesitation while it is totally warmed up, or still on choke? Idle circuit cruddy my first guess. Clutch replaced at 3,200 miles, yikes. My dry clutch Ducati race bike did better miles than that!
Old Oct 31, 2020 | 05:26 PM
The choke (enrichener) cable has a twisty thing-a-ma-bob at the pull **** to adjust tension or, I suppose, to lock it in place.
Old Nov 1, 2020 | 05:07 AM
Wicky's Avatar
Could be a few things - As mentioned you can adjust the choke cable tension by tightening up the adjuster ring. With the low milage fuel could have gone off and gummed up carbs. Also has it a standard or aftermarket air filter? Did PO do any carb tuning to compensate for the exhaust? Plus are the various tank hoses in fine fettle and correctly postioned esp the vacuum hose to the fuel tap.
Old Nov 2, 2020 | 12:50 PM
tosainu1's Avatar
It runs poorly whether cold or warm. When you rev it, you don’t get a smooth throttle response. It’s jerky at times and wants to wheelie at times and sometimes it doesn’t respond. No adjustments were made to the carb after the installation of the exhausts. They are Delkevic 8” slip on pipes. It was running the same way prior to the install of the pipes. My local Honda dealer won’t touch the bike. The dealer charged me for a long list of things he said he did to no avail and kept mother bike for months... I was able to fix the issue with not being able to keep the choke out though, thanks for that advice !! Any further help would be appreciated.
Old Nov 10, 2020 | 04:57 PM
With such low mileage, who determined it needed a new clutch?
And do you know anyone who is comfortable working of carbs?
Old Nov 10, 2020 | 06:10 PM
tosainu1's Avatar
A local shop put the new clutch in but didn’t fix the carbs if anyone knows a pedi or shop in Md familiar with these carbs let me know I want to put a jet kit in to compensate for the slip on pipe
Old Nov 11, 2020 | 07:06 PM
You don’t need a jet kit for the pipes. There’s a thread on jetting. One thing at a time. Get to baseline first.
I had a set done for an ‘84 Nighthawk by https://www.wgcarbs.com/ carbs looked like new.
Old Nov 12, 2020 | 12:12 PM
tosainu1's Avatar
Thanks for the reply
I’m going to send them out to get cleaned and the jet kit installed since they quoted me
$349 at wgcarbs. I’m going to also do oil and air filters, manual cam chain tensioners, radiator drain and refill, spark plugs for now to have a good baseline...
Old Nov 12, 2020 | 05:11 PM
killer5280's Avatar
What air filter is in it now?
Old Nov 13, 2020 | 01:36 PM
While you're in the air box, consider replacing the sub filters also. My guess is they are rotten.
Number 10 https://www.partzilla.com/catalog/ho...wk/air-cleaner
Old Nov 14, 2020 | 04:04 PM
tosainu1's Avatar
Thank you for that extra advice I have no idea what filter is in there and though I was told it wad low mileage it actually has over 15k miles on it... 5 times the mileage I was told it had...
Old Nov 14, 2020 | 06:50 PM
Wicky's Avatar
Small furry animals or waspy fings sometimes find airboxes makes an attractive nest / nut stash.
Old Nov 22, 2020 | 09:33 AM
tosainu1's Avatar
That’s crazy!
Old Nov 27, 2020 | 10:09 AM
JamieDaugherty's Avatar
Originally Posted by YMRacing
Fuel tank vent
I'll bet that's the problem.
Clean out the tank cap really well. I suggest removing it from the tank first so you can blast it thoroughly with carb cleaner.
If you want to verify this is the problem, ride it until it has the problem then pop the cap to allow air to come in. Pretty easy to do especially if you have a spare key.
Old Nov 27, 2020 | 10:26 AM
tosainu1's Avatar
Very interesting
This sounds like a simple solution I’m definitely going to try it and thanks for this I appreciate it
Old Nov 28, 2020 | 08:15 PM
tosainu1's Avatar
Question
When i removed the gas tank partially I see that of the 6 screws holding down the air box five are missing. Only the one at the top right is fastened. Will that cause an issue with the motorcycle or is that cosmetic(excuse my ignorance please )? i don’t know...
Old Nov 28, 2020 | 09:44 PM
tosainu1's Avatar
Old Nov 28, 2020 | 09:46 PM
tosainu1's Avatar
I ran a bike cable all the way through and found no real obstructions to speak of...
Old Nov 29, 2020 | 03:29 PM
YMRacing's Avatar
That's the fuel overflow, not the vent. The vent is in the locking fuel cap. It is vented to the atmosphere.
Old Nov 29, 2020 | 04:14 PM
tosainu1's Avatar
How do I test for an obstruction in the fuel cap?? Does it matter that I’m missing 5 out of 6 air box screws as far as how the bike runs or is it just cosmetic??
Old Nov 30, 2020 | 11:56 AM
Cadbury64's Avatar
VTR virgin
The missing screw in the airbox lid won't matter; it just helps to hold the filter in place and seal out dust from bypassing. Any self-tapping scew can be used there. The fuel tank breather is the smaller hose plugged into the bottom of the fuel tank (the bigger one goes to the overflow by the cap). Pull the small hose off and check that is open to atmosphere, and also blow through the spigot on the tank and make sure it is clear. There's no breather in the fuel caps (unless the US bike is different to the rest of the world), you can flip the tank over on its back and it won't leak. You can unbolt the fuel petcock and pull out the strainer in the tank for a check.
The other thing to check is the general condition of the small black rubber vacuum hose going to the fuel petcock (must have no cracks) as the engine vacuum is used to keep the vacuum fuel tap open to let fuel flow to the carbs. Any leak here can stop the fuel flow and give the poor running you describe. There is also a rubber diaphragm in the petcock that can perish and stop fuel flowing easily.
Old Dec 3, 2020 | 01:20 PM
tosainu1's Avatar
Thank you for your reply I will check the vacuum hose and most likely replace it. I just came from the dealer and I ordered a bunch of parts to include the air filter assembly, oil filter, sub filter, air box screws etc etc. I will get down to the bottom of the problems of this bike because it has a **** ton of character compared with my other bikes..
Old Dec 3, 2020 | 03:24 PM
YMRacing's Avatar
Easiest way to check is to leave the gas cap cracked open. If it runs fine...then it's the gas cap vent. Do an ultrasonic cleaning on the cap.
Old Dec 11, 2020 | 02:45 PM
tosainu1's Avatar
Ultrasonic cleaner
Went to harbor freight and bought me an ultrasonic cleaning machine to see if that will fix the problem
Superbroke
Aug 9, 2011 01:11 PM
babyhawk
Feb 12, 2011 09:40 AM
lovemyhawk
Mar 27, 2007 01:00 PM
DaxMiddler
Apr 28, 2006 03:22 AM
faz
Oct 6, 2005 10:09 AM
