Rotor Question
Old Feb 20, 2010 | 11:03 AM
stebbdt's Avatar
COBB Member
Rotor Question
Hey guys, just have to ask this one, is it critical on the rotors to have a left and right, you know, does it really matter directionally? Reason I ask is I got a set for my fork swap and the guy sent two left's. I contacted him and he has no issue with making the swap as he now has two rights, but he claims that it really doesn't matter.
Thanks for helping, I'm sure this is just the first speed bumb I'll hit on this project.
Old Feb 20, 2010 | 11:15 AM
What bike are the rotors off? Stock or aftermarket? If I look in my Dennis Kirk catalog, at least as far as part #s, some bikes have the same part# for left & right and some don't. Some aftermarkets are directional and some non-directional. If they're stock look up the part#'s on a microfiche like ronayers.com and at least see if they have the same part #s and go from there.
Old Feb 20, 2010 | 01:07 PM
peterpanic's Avatar
pragmatic anarchist
Yeah, I've always wondered about them itty bitty arrows. What if I back up alot?
Old Feb 20, 2010 | 01:16 PM
jay956's Avatar
the parts them selves should be the same. the problem would be the wear pattern. your pads and rotors wont match at first so you wont have 100% of braking capability. your pads will probably wear faster until they are bedded in with the rotors. i think you should be fine, jsut give yourself 100-200 miles before you do any hard braking.
Old Feb 20, 2010 | 02:43 PM
stebbdt's Avatar
COBB Member
Yeah Capt, they're stock 320mm take off's for the rc51 fork swap I'm doing, Ron ayers shows em as left and right diff. part #'s.
Jay, I know the offset is the same, don't know the reason for the directional arrow, but I'm thinking it's there for a reason, maybe just to address the wear pattern issue if ya have to pull em off for some reason, like a tell tale to guide you for re-assembly.
Pete,
I hear man, lol.
Probably just best to take the time to swap him 1 for 1 I guess.
Thanks aLL.
Dave
Old Feb 20, 2010 | 04:00 PM
On some of the bike's the rotors are drilled in a pattern that's supposedly gives "better cooling" without increasing wear on the pads... I think the effect is rather marginal at best...
Wear pattern... Yeah... But the issue of bedding in the pads to a set of used rotors are there regardless of the arrows... Doesn't matter what way the arrow points, you should still go over the used rotor with a fine grit sandpaper and then clean it really good... And if you are using new pads, that's it apart from taking it easy until they are bedded in... If you for some reason are using pads that have been used, sand them flat as well before...
Old Feb 20, 2010 | 04:56 PM
stebbdt's Avatar
COBB Member
Yeah Tweety, they have some use on em before the PO swapped em out for a set of those cool wave jobbies, I plan on bringing em into work and bead blasting em then hit em with with contact cleaner. New pads are definatly on the list. Hell I didn't even know the things had directional markings until I read it on someones post on here, lol now that I know about it, I gotta deal with it, crap, sometimes ignorance is bliss. Sometimes not.
Man, I think I've caught some sorta condition from youz guys heheheh.
Old Feb 20, 2010 | 04:59 PM
Oh just wait...it gets worse (better?)
Old Feb 20, 2010 | 05:56 PM
Erik S.'s Avatar
I'll say worse. Stebbdt, you're already showing early signs of OCMD.
Old Feb 20, 2010 | 06:59 PM
stebbdt's Avatar
COBB Member
OMFG not OCMD, WTF?
Old Feb 20, 2010 | 08:24 PM
nath981's Avatar
if you back up a lot, you might be a coward. or worse.
Old Feb 20, 2010 | 09:12 PM
nath981's Avatar
I wouldn't worry about the arrows if the rotors center in the calipers when mounting the wheel. If you have a little sand blaster or sander, I would clean the rotors up evenly and the same with your pads after you determine proper fit.
Old Feb 21, 2010 | 05:28 AM
JDRiderCoach's Avatar
JDRiderCoach is on a distinguished road
LMFAO
Old Feb 21, 2010 | 06:40 AM
peterpanic's Avatar
pragmatic anarchist
What's worse than a coward? Shawk has no reverse so backing up a lot usually involves a steep hill. Not so cowardly, not with those mirrors!
Old Feb 21, 2010 | 09:05 AM
nath981's Avatar
what's worse than being a coward relative to backing up? you might wanna consult some of your friends in the bighouse.hahaha
don't panic peter. lighten up. just bustin *****
Old Feb 21, 2010 | 11:45 AM
comedo's Avatar
In addition to whatever else they may do, if anything, the little directional arrows help when you show the genius who just mounted a new tire on the front wheel that he put it on backwards.
Old Feb 21, 2010 | 11:59 AM
PUSHrod's Avatar
When I did the 900 RR front end installation on my Hawk I used the original wheels and brakes. The rotors are handed. There is a Left and a Right. Confusing them causes the centering in the calipers to be off.
Tuition is cheap for you if you learn from my experience.
Old Feb 21, 2010 | 01:26 PM
Actually the rotors are the same, no difference at all in offset... The spacers or the rim might be asymmetrical, but I highly doubt it...
Old Feb 21, 2010 | 05:02 PM
peterpanic's Avatar
pragmatic anarchist
Backing up...friends in the big house...peter panicking...and you think "just bustin *****" will help lighten that up? Bustin ***** doing what exactly? Nope, let's end it. Don't even wanna know! hahaha+
Old Feb 21, 2010 | 07:00 PM
nath981's Avatar
i guess this means that when I visit my cousin in South Philly this summer, that I should not bother to let you know.
Old Feb 22, 2010 | 06:43 AM
peterpanic's Avatar
pragmatic anarchist
Ah, humor's a funny thing! All in fun, otherwise I'd be guilty of a threadjack, worse than cowardice or even that other thing you alluded to! South Philly's cool, but we better stay off South Street, they don't like that kinda joking in the Gayborhood!
Old Feb 22, 2010 | 01:20 PM
nath981's Avatar
I moved in with my cousin for 6 weeks(right across from the stadium) to help him with a construction job he took but got more than he bargained for. He is the king of ball bustin and 18 hrs a day with him changes one forever.
I did shoot at a queer in downtown LA when he wouldn't leave me alone. I verbally warned him first, kicked his door in the second time, and the third time I fired 3 shots at him with my 32 as he sped away; fortunately, I was impaired enough to adversely affect my ability to hit a moving target in the dark.
outrigger
Mar 15, 2013 08:03 PM
ali_squidz
Mar 31, 2007 06:42 PM
CNI Dawg
Feb 4, 2007 06:16 PM
Radiaoktiv
Dec 27, 2006 11:44 AM
superhawk22
Aug 22, 2005 05:22 PM
