Replacing starter enrichment plungers
Old Aug 23, 2019 | 08:57 PM
69Rider's Avatar
69Rider is on a distinguished road
Searched the KB first but didn’t find the info I need. I picked up a used 2003 ‘Hawk and I’m trying to replace a missing starter enrichment plunger for the front carb. How do I make the cable end longer so I have enough to pull the cable stop through the new spring and choke plunger? I don’t see any obvious way like the throttle cables with their length adjusters.
Old Aug 24, 2019 | 04:24 AM
belray's Avatar
belray is on a distinguished road
I think you would compress the spring
Old Aug 24, 2019 | 05:40 AM
With the choke **** pushed in, there should be plenty of cable to go though the choke tube nut and spring then slip the cable end into the starter valve
Old Aug 26, 2019 | 01:03 PM
69Rider's Avatar
Ok, thanks all! I was able to get a but more cable play by removing the cable assembly. Snapped one of those damn plunger bodies installing the carbs after a clean/rebuild. Already messaged JackFlash to buy a pair of his brass replacements. Waiting on a replacement tank from eBay (couldn't save the rusted out original, too many pinholes).
Old Aug 26, 2019 | 01:17 PM
LOL Pin holes????? I think I have a different definition of a pin hole then you,
Strange, I thought the general line of thinking was guys OVER estimated the size of, ummm, stuff
Old Aug 26, 2019 | 02:08 PM
69Rider's Avatar
Ya, I saw a few bubbles under the paint when I got the bike. The prev owner left it parked for 8 years with 3/4 tank of fuel. I knocked the loose rust flakes out with 3lbs of drywall screws, and filled it with some Prep & Etch phosphoric acid to get rid of the rest. I knew the tank was pretty much worthless, but I thought I'd confirm. Yep, she's toast!
Old Nov 18, 2022 | 02:45 PM
acf's Avatar
acf
acf is on a distinguished road
thanks for the good pictures. I am replacing my SE valves today. Mine is the same blue - nice colur
TAMPAHAWK68
Mar 15, 2014 06:53 PM
superhawk22
Feb 21, 2012 11:58 PM
Hardhead
Aug 2, 2008 06:29 PM
Dave Wicks
Mar 15, 2007 05:37 AM
acxprs
Oct 15, 2006 02:09 AM
