Choke knob repair?
Old Feb 20, 2014 | 05:57 AM
TAMPAHAWK68's Avatar
TAMPAHAWK68 is on a distinguished road
Choke **** repair?
Yep, another choke **** that doesnt stay out like it is supposed to. The tension adj collar is as tight as it will go and still wont say out. I was thinking about putting a rubber behind tension collar to add some friction to choke **** shaft. Try something like that first. Replacing cable is not an option..too much of a hassle. Anybody have any other ideas or found a solution to fix other than new cable?
Old Feb 20, 2014 | 06:01 AM
Wicky's Avatar
Pretty easy to do - just tank and airbox off and simply dislodge carbs. an hour or so to do.
Old Feb 20, 2014 | 06:15 AM
I know how to replace cable, just don't want to go thru all the trouble to do so. just seeing if anyone found a quick fix for it. My idea should work, just seeing if anyone has come up with something before I try experimenting.
Old Feb 20, 2014 | 06:41 AM
I unscrewed tensioner and put a small rubber o ring behind it. Works good as new now...took longer to find an o ring that would fit, than to fix..FYI for anyone having same issue
Old Mar 1, 2014 | 12:38 AM
Same as Tampa, o ring works!
Old Mar 1, 2014 | 01:58 PM
Glad I could help..another choke cable tidbit..If for any reason you have to remove your carbs, disconnect your choke cable, remove bracket and pull cable along with carbs. Much easier to remove/install elbow fittings and you can verify function of choke before you install on bike, and if it fails to function right after installation....check your work.
Old Mar 1, 2014 | 08:11 PM
Tofazfou's Avatar
Tofazfou is on a distinguished road
Maybe what you don't want to hear but about 4 weeks ago, I stopped using that POS choke ****. My **** is so sensitive anyways for the sweet spot to start my bike. You have to pull it out just enough but NOT TOO MUCH...lol. And when its cold outside, you can just about forget about using my choke ****. Mine also has lost friction and can't even hold a LITTLE pull on it without going back in some.
What I do is simple and its not hard to do everytime I cold start my bike and that is................................................ ......
Leave the friggen choke in and simply turn my idol screw about half to three quarters of a turn to raise idle. When the bike is warm, I simply turn it back down till the needle hits the 1100-1200 mark and off I go. Turning the idle screw up about half to 3/4 of a turn on my bike is about 1600 rpm or so.
Old Mar 2, 2014 | 12:17 AM
The last thing you want is a sensitive **** eh!
Also great tip about the choke cable as I have suffered from the broken P.O.S plastic elbow breaking.
Caused all sorts of drama when both elbows cracked and bike ran like s it!
Happened when I put the Dynojet kit in and boy was I disappointed that I couldn't ride my bike.
I have since removed the carbs a couple of times and always leave the choke cable attached!
Old Mar 2, 2014 | 05:46 AM
Wow! I'd hate to have to do that every time I wanted to ride. Mine is extremely sensitive when it comes to how the cables are routed. After I did the o ring fix and got the **** to stay at any position I want. I pulled **** out, fired up bike and it wouldnt idle for sh*t. Found out the front cable was binding just enough to cause my problem. I believe 90% of choke cable issues are self inflicted. except for the tensioner wearing out.
Old Mar 2, 2014 | 12:06 PM
Tofazfou's Avatar
hey I get it. At some point I will try the oring mod as I have a million of em laying around anyways thanks to all my air guns.
I guess for me, I don't ride my bike everyday. Only on weekends so i'm not on it a lot like probably many folks are. Its just not that big of a deal for me to turn the idol ****.
My tensioner simply wore out like many of you. So i'll get around to oringing the **** one day. Just another thing to fiddle with on this bike.....lol
Old Mar 2, 2014 | 07:45 PM
rz_racer_69's Avatar
Old and dangerous
I don't have that much trouble with mine. Tensioner is likewise useless. I just suit up, hold the **** out by putting my finger in the way, start it and hold it like that for 15-30 seconds. After that it's easy to keep running by blipping the throttle a bit. Then I roll off, and ride nice and easy for a while. No drama. Guess it helps I'm used to old two-stroke race bikes that were jetted so fat they wouldn't idle, lol.
Old Mar 3, 2014 | 07:00 AM
Faulty chokes are more embarrassing than anything else. How cool do you look, when your buddies riding fi bikes have long since left you standing in the parking lot with you holding your ****! just my 2 cents. lol
Old Mar 3, 2014 | 08:00 AM
Old and dangerous
I hold my **** with pride!
Then I blow past them in the corners!
Old Mar 3, 2014 | 10:56 AM
brothermike's Avatar
brothermike is on a distinguished road
Ditto.
Old Mar 3, 2014 | 12:37 PM
Old and dangerous
One nice aspect of having a "self-retracting" choke (I prefer that over "defective"), I don't have to worry about riding around with my choke on when it is no longer desired, lol. I always thought it was a cool feature.
Old Mar 15, 2014 | 09:53 AM
102dals's Avatar
I moved mine to the handlebar a long time ago. Thanks to an Inderocker thread, then it can retract whenever.
Old Mar 15, 2014 | 10:57 AM
"Feature"? Do you write software for a living?
Old Mar 15, 2014 | 06:53 PM
Old and dangerous
Lol, I have been an applications designer in a past life.
Now I'm an IT administrator.
Anto
Sep 11, 2007 12:14 AM
Pookbe
Apr 25, 2007 11:12 PM
lovemyhawk
Mar 27, 2007 01:00 PM
Randman
Jun 29, 2006 02:06 PM
reelectreagan
Jun 17, 2005 07:31 AM
