Replacing my R/R
Old Feb 24, 2009 | 06:32 PM
jkrswld's Avatar
jkrswld is on a distinguished road
Replacing my R/R
New R/R came in now I need to replace it can anyone help me out with this. I was told it is fairly easy just need to know where to start.
Old Feb 24, 2009 | 06:44 PM
skoshere's Avatar
here you go...
https://www.superhawkforum.com/forum...ad.php?t=14380
Old Feb 24, 2009 | 07:54 PM
For a simple swap with OEM parts, remove the seat, remove the rear cowl. R/R is on the right side, has two bolts, and one connector. Check connector cleanliness and overall physical integrity and also check the mounting area on the subframe for cleanliness. Half of the heat removal is probably through that contact on the subframe.
Old Feb 25, 2009 | 01:29 PM
jkrswld's Avatar
Thanks should be swapping it out tonight and riding tommorrow!!!!!!!!!!
Old Feb 26, 2009 | 02:03 PM
PUSHrod's Avatar
and take an extra five minutes to clean out any corrosion you find on the ground or the connectors. Di-electric grease completes the job and forestalls the time of the next failure.
mikstr
May 3, 2007 05:38 PM
Otto Man
Jan 6, 2007 01:36 PM
seattlesucks
Jun 23, 2006 01:49 PM
mikstr
Jun 16, 2006 07:36 AM
smonska
May 31, 2006 04:45 PM
