replacement tachometer
Old Jun 4, 2008 | 11:55 AM
nevinreilly's Avatar
nevinreilly is on a distinguished road
After a lot of post-R/R failure (overcharged) electrical testing and part replacing my only remaining problem is a non-functioning tach. Following electrical tests in the manual I traced the problem to the CDI or tach itself. The bike starts and runs great which leads me to believe the tach is the problem. It has power going to it and before the bike died from the R/R the tach went crazy.
Bike is a 1998 with all analog gauges. Dealer says $215 for a new one but I'll try to find something used.
Anyone else have the tach killed by the R/R? Ever replaced one? How difficult is splitting the gauge cluster?
Finally, any other tests I can do to make sure the tach is in fact the problem?
Thanks for the help.
Nevin
Old Jun 4, 2008 | 12:40 PM
superbling's Avatar
No but mine took out a brand new $20 silverstar headlight which is in the general vicinity and the battery; 18+ volts at idle. Sounds like the tach ate it.
$215 is retail. Servicehonda.com has it for $157. Haven't watched ebay in a while but I doubt you can find a used set of gauges for less than that amount.
Old Jun 4, 2008 | 01:56 PM
riderone's Avatar
riderone is on a distinguished road
LOOKY LOOKY http://cgi.ebay.com/ebaymotors/Honda...mZ120266801838
Old Jun 4, 2008 | 02:01 PM
superbling's Avatar
Originally Posted by riderone
He has it posted in the frames section. His mistake can be your gain. LOL
13 bids and it's only at $20? Last of the big time spenders here.......
Old Jun 4, 2008 | 04:01 PM
BeerHunter's Avatar
Slacker
Replacing components in the cluster assembly is extremely easy to do... the backside of the unit is completely open.
Old Jun 5, 2008 | 06:44 AM
Thanks. Unfortunately missed bidding and the only other gauge cluster is $200 BIN.
Regarding disassembly, I've had the cluster off but didn't know if it was glued/sealed in addition to the hex screws.
ima98chickenhawk
Jul 5, 2010 07:16 AM
inderocker
Oct 3, 2009 11:21 PM
cliby
Jul 29, 2008 04:28 AM
jim6540
Jan 27, 2008 09:15 AM
wardo996
Mar 21, 2007 10:20 AM
