Reg/Rec problem...need help!
Old Nov 15, 2009 | 09:02 AM
NCDave's Avatar
Ok, so I ordered an R6 rectifier to install on the SH. It arrived yesterday and I started putting it in.
Apparently the order of the wires seems to have some importance, particularly with the red and green wires. If I plug them in one way, they blow the main fuse (a 30 amp one). If I plug them in the opposite, it doesn't blow the fuse, but it's also not charging the battery either.
If I plug the old unit back in, it works fine.
Any ideas????
The R6 unit I got was for a 97 to 02 model. Apparently it fit the R1 as well.
Help!
Old Nov 15, 2009 | 10:17 AM
AngryOlaf's Avatar
There's an R6 Rectifier Swap How-to right at the top of the Knowledgebase section of the forum.
Hope you didn't damage yours blowing the fuse!
Old Nov 15, 2009 | 10:24 AM
pigwings's Avatar
pigwings
R6
I use a 02 R6 RR. Worked fine after I got the wires right. There's a very helpful how-to in the knowledge base with this diagram.
Attached Thumbnails Reg/Rec problem...need help!-rr_mod_plug.jpg
Old Nov 15, 2009 | 11:09 AM
NCDave's Avatar
Thanks guys. I had looked at the how-to thread. I just forgot which side the red and green were on. I think I also had forgotten the ground, because I went back and re-installed it, and it seems to be working fine now.
thanks for the input!
sheldonsl
Nov 16, 2010 03:09 PM
motormouth
May 31, 2010 02:32 AM
smokinjoe73
May 8, 2010 11:20 AM
Shaggie
Mar 20, 2010 08:32 PM
Redhawk996
Jul 21, 2004 02:09 PM
