Rectifiier
What is the issue your having?
What RR did you swap in?
Is it wired directly to battery? If so though a fuse or a breaker?
If its one of my kits, you just need to reset the breaker
Ahh, ok so its and aftermarket pattern part
Have you checked the main fuse? and the fuse terminals to make sure they are good?
Checked the RR to make sure there are no opens? Or shorts to ground?
With key on, is there power to the fuse box?
When you push the starter button, what does the voltage drop to?
I got her a sister to use for parts. She has bent shift forks and I didnt want to pull the motor, so I swapped over all the goods. I did a lot in a short amount of time and got tired, maybe impatient. I should have disconnected the battery. Glad there's a fuse, but even more glad I have this forum for support. You guys have never let me down and I would never have had the best first riding experience over the past few years without all your help. Big fan of all you guys. Cheers, and ride safe
