Recommended Tire Pressure
Old 07-17-2007, 11:07 AM
Dirty Bird
hawkbill's Avatar
hawkbill is on a distinguished road
Guys,
My rear Pilots wore out after about 7-8 months of use, estimated 2800miles. I weight close to 200lbs with gear on so I set my tire pressure at 40-42psi as that's what's on the mfg sticker on the chain guard. However, when I had the tire replaced, the shop set tire pressure at 36psi which is where the front is set. What experiences have you guys had with tire pressure for street use and tire longevity?
hawkbill is offline
Old 07-17-2007, 11:10 AM
Use the search tool, there are numerous threads on this topic....
mikstr is offline
Old 07-17-2007, 01:47 PM
bowhawk's Avatar
Pilot Powers. I run 34 rear and 32 front on the road. At the track I start at 32/30 as the tires heat up more. Any higher and the rear breaks loose too easy and the front seems to wander. For commuting/touring you may want to go higher to reduce the flat spotting.
bowhawk is offline
Old 07-19-2007, 08:59 AM
ride57's Avatar
ride57 is on a distinguished road
The Michelin man at the track said: 36 f 35 r. YMMV
ride57 is offline
Old 07-19-2007, 09:20 AM
Post Whore Junior
Cleveland's Avatar
ok, fine i'll bite too...
Rear 30 cold for road, front 32 cold for the road.. got nearly 8k out of my rear Pilot, front still got lots... I dont track ride.. just commute mostly, and a couple trips.
Cleveland is offline
Old 07-19-2007, 03:18 PM
superhawk22's Avatar
8K damn I've never even sniffed that on a rear tire!!! Damn right wrist.....bad wrist bad!!!
superhawk22 is offline
Old 07-19-2007, 07:20 PM
NovaWildcat08's Avatar
NovaWildcat08
Tire pressure will depend on the tire you're running. Each tire is different. Generally though, people will run higher pressures commuting and on the highways and lower pressure in the twisties.
NovaWildcat08 is offline
Old 07-20-2007, 04:30 AM
Post Whore Junior
Cleveland's Avatar
Ya know thinking on it.. I am hard with the wrist too... I put the tire on around 9k odo read (I know the first # was 9.. the rest I am unsure of).. I am past 16k now... and still have tread.. so I am estimating that it'll be 8k if I run it to the threads... Cross my heart...
Old 07-20-2007, 07:14 AM
L8RGYZ's Avatar
Cleve... is that a Road or a Power?
L8RGYZ is offline
malken00
08-24-2006 05:52 PM
Les
01-26-2006 02:58 PM
CNI Dawg
01-01-2006 10:02 PM
pickle.of.doom
08-26-2005 04:53 PM
99Hawkboy
07-31-2005 12:47 PM
Quick Reply: Recommended Tire Pressure
