Rear tire being shredded by my chain.
Old May 26, 2018 | 09:49 AM
PoorMansDucati's Avatar
PoorMansDucati is on a distinguished road
My chain appears to be shredding the sidewall on my tires.
I got about 3 - 4000kms on these new tire before i started to notice this slight wear. Two or three days later, they looked like the above picture.
I thought it had to do with an aftermarket chainguard I installed, and ai was actually going to make a separate post about them, becausr Ive had nothing but problems with them, but I switched back to the stock plastic one and it still got worse.I changed my chain and sprockets, (which I've done before with no issue, stock size, 550 DID riveted)
Old May 26, 2018 | 09:53 AM
What size is the rear tire? Wheel/spacers installed on the axle correctly? Bike ever been wrecked? Bent frame/swingarm? Running the correct drive flange for the sprocket?
Just throwing stuff out there...a lot of stuff can happen to a bike over 20 years.
Old May 26, 2018 | 10:01 AM
The rear tire is stock size. Nothing bent. Im not sure about the wheel spacers. Ive never removed them. Looking at the manual, everything seems right. I must have screwed up something. She's had no issues for 20,000 + kms I've put on her. Is there more detaile informationd about the spacers cap?
Old May 26, 2018 | 10:04 AM
The aftermarket chain guard kept bending and breaking, but along the reline axis...inward toward the tire.
Old May 26, 2018 | 10:07 AM
https://www.ronayers.com/oemparts/a/...2e2/rear-wheel
Old May 26, 2018 | 10:08 AM
So is the chain hitting the tire or the chainguard?
Old May 26, 2018 | 10:15 AM
Sorry to trouble you cap. It turns out, stainless steel passenger peg spacers I made, weren't quite out far enough. This was causing my exhaust hanger to rub on my tire....what a costly mistake...
Old May 26, 2018 | 10:20 AM
I still don't know why the chain uard bends and breaks, but I suspected it was the culprit until I changed it back to the stock one, and the tire still got shredded. I thought the information may have been relevant to a diagnosis, ie, swingarm or some such issue
Old May 26, 2018 | 10:40 AM
No worries. Glad you got it figured out. Better safe than sorry.
rick
Jul 31, 2014 10:56 PM
thedeatons
Feb 9, 2014 07:12 AM
Tweety
Nov 30, 2007 07:00 AM
nuhawk
Aug 20, 2007 06:59 PM
selztoad
Oct 24, 2006 06:58 AM
