Rear tire being shredded by my chain.
https://cimg6.ibsrv.net/gimg/www.sup...4bc886e522.jpgMy chain appears to be shredding the sidewall on my tires.
https://cimg8.ibsrv.net/gimg/www.sup...0fc75e6509.jpgI got about 3 - 4000kms on these new tire before i started to notice this slight wear. Two or three days later, they looked like the above picture. https://cimg1.ibsrv.net/gimg/www.sup...b73b614e78.jpgI thought it had to do with an aftermarket chainguard I installed, and ai was actually going to make a separate post about them, becausr Ive had nothing but problems with them, but I switched back to the stock plastic one and it still got worse.I changed my chain and sprockets, (which I've done before with no issue, stock size, 550 DID riveted) |
What size is the rear tire? Wheel/spacers installed on the axle correctly? Bike ever been wrecked? Bent frame/swingarm? Running the correct drive flange for the sprocket?
Just throwing stuff out there...a lot of stuff can happen to a bike over 20 years. |
The rear tire is stock size. Nothing bent. Im not sure about the wheel spacers. Ive never removed them. Looking at the manual, everything seems right. I must have screwed up something. She's had no issues for 20,000 + kms I've put on her. Is there more detaile informationd about the spacers cap?
https://cimg1.ibsrv.net/gimg/www.sup...e486175186.jpgThe aftermarket chain guard kept bending and breaking, but along the reline axis...inward toward the tire.
https://cimg4.ibsrv.net/gimg/www.sup...2b2c419ec6.jpg |
So is the chain hitting the tire or the chainguard?
Sorry to trouble you cap. It turns out, stainless steel passenger peg spacers I made, weren't quite out far enough. This was causing my exhaust hanger to rub on my tire....what a costly mistake...https://cimg7.ibsrv.net/gimg/www.sup...e7544978e5.jpg
(Post 406283)
No worries. Glad you got it figured out. Better safe than sorry.
