Rear Tire
Old Feb 24, 2005 | 04:34 AM
Ohio Hawk's Avatar
Rear Tire
First off Hello everybody...I`m new to the forum and this is my first post...
I have been running the stock size rear tire on my 99 Hawk and would like to know if any of you are running or have tried a 190-50-17 on the rear and what were your likes and dislikes...
Old Feb 24, 2005 | 07:22 AM
superbling's Avatar
Re: Rear Tire
Most 190's are meant for 6 inch rims. The VTR has a 5.5. You have to pinch the beads much tighter to fit. If you mount your own tires by hand like I do, you won't like this side effect at all.
The intended profile will change giving you a smaller contact patch than if on a 6 inch. This also slows down your handling. The tire won't look as wide as it could which is the most common (if unstated) reason for going with "meatier" tires but yes it will look wider than the stock 180. Your unsprung mass is increased somewhat which theoretically slows down your suspension reactions.
Old Feb 24, 2005 | 09:27 AM
faz's Avatar
faz
faz
Re: Rear Tire
welcome aboard.
those whose bikes come with 190s change them to 180 usually at the first tire change time, to get faster turning response.
Other than visual effects, 190s do not provide any advantage over 180s, so why bother??
Old Feb 24, 2005 | 12:10 PM
Ohio Hawk's Avatar
Re: Rear Tire
Thanks for the replies... I'm ready for another new Pilot Sport and was just thinking about a 190 but I guess its not the thing to do... I can`t wait for WINTER to be over so I can ride.... I moved up here to Ohio back in Nov from Houston were I rode year round.
Old Mar 3, 2005 | 12:49 PM
vitter's Avatar
vitter is an unknown quantity at this point
Re: Rear Tire
http://sportrider.com/tech/tires/146_0206_size/
Old Apr 4, 2005 | 10:26 PM
RymerC's Avatar
RymerC
Re: Rear Tire
care if I jump in on some of that action?
I'm dying for someone to ride with around here. It's just me and a good buddy now, but the way he's been crashing his Triumph it might not be around too much longer...
Old Apr 5, 2005 | 06:00 AM
Ohio Hawk's Avatar
Re: Rear Tire
I just moved up here back in Nov from Houston and not riding year round will be hard... but the weather is getting better so its time to ride... I`m always up to meeting new riding buddys...as long as you don`t mind riding with a old man...
Old Apr 5, 2005 | 10:42 AM
SurfaceHawk's Avatar
SurfaceHawk
After I picked up a Key, (yes an ordinary house key) in the rear tire, I had a 190/50 put on, (emergency only tire in the county away from home), the bike tended to fall into corners and wore out extremely quickly. Apparently the contact patch is greatly reduced when upright. I switched back after I wore it out, had to be only about 1800 miles. that was with a Metzeler Sportec M-1. By the way, a great tire, but they wear too fast.
98dreamsuperhawk996
Nov 7, 2006 10:34 AM
spacemonkey
Apr 23, 2006 06:18 AM
Brian A
Apr 7, 2006 11:36 AM
Coloradoray
Jun 21, 2005 02:42 PM
thegreep
May 22, 2005 03:23 PM
