Rear Shock Safewty Warning
Old Oct 25, 2014 | 03:19 PM
cybercarl's Avatar
Wasn't sure this should be in the Knowledge Base or not. It can always be moved if needs be.
This needs posting over here as it's a safety issue which members need to be aware of.
Recently over the pond we had a member who's original VTR shock preload adjuster ring snapped and the shock collapsed on him, luckily this happened at low speed.
www.vtr1000.org • View topic - My rear shock collapsed!
After a bit of investigation and keen eyes it's looking like the preload adjuster ring is not manufactured as one piece and has been spot welded together. Others have checked their OM shocks and it seems the same for all. Shocking to say the least (no pun intended).
Anyone that is still running a standard rear shock be aware of this and include it in one of those vital areas that should be checked and please don't go using a hammer and drift to move the adjuster as this would weaken it. Always use a C spanner.
I'd be interested in JD's opinion on this.
Old Oct 25, 2014 | 04:01 PM
thetophatflash's Avatar
Looks like the work had been done with a hammer and screwdriver based on the mark on the collar.
Old Oct 25, 2014 | 04:21 PM
another good reason to get an Ohlins
Old Oct 25, 2014 | 06:52 PM
Another good reason to not use a hammer as a suspension tool.. Millions and millions of motorcycle rear shocks use a stamped, rolled spot welded steel preload adjuster,,
Did that ONE preload adjuster fail, looks that way....but it's not a reason to condemn them all. By all means have a look at yours and see if the spot weld is fractured
Old Oct 25, 2014 | 09:26 PM
Once that failed, how far can the shock collapse? Completely? It seems it could only collapse the thickness of that collar(?).
My Penske shock failed and the shock (slowly) collapsed completely. I think the only reason it didnt tip the bike was that I have the shock spacer. Had to ride back from Manhattan to Brooklyn. What an uncomfortable ride. Bone jarring I would say.
Old Oct 26, 2014 | 03:49 AM
cybercarl's Avatar
I never knew that. It doesn't seem the best design to me. Surly the spot weld will always be a weak point.
It completely collapsed so the spring unsprung, releasing all it's energy under the butt as it shot upwards. Suspension collapeed to the point of the bike being unrideable. Wouldn't even stand up on the sidestand.
The preload adjuster ring has snapped in two, allowing the spring to rise right up to the top mounting bolt area.
Old Oct 26, 2014 | 07:42 AM
"Suspension collapeed to the point of the bike being unrideable. Wouldn't even stand up on the side stand." I think you were the one that "collapeed" . lol
Old Oct 26, 2014 | 03:24 PM
cybercarl's Avatar
Your not wrong.... collapsed in shock that it happened and that it's designed that way. I got to say it played on my mind a couple of times while riding on faster laborious motorway (freeway to you) style riding. I think I will be getting an aftermarket shock sooner rather than later now. Having something like suspension linkages seizing up is one thing but the thought of a shock collapsing at high speeds is something else
Old Oct 26, 2014 | 05:27 PM
jerryh's Avatar
Before we all collapeed all over ourselves maybe someone can whip some up for free. Mat aka cruxGNZ of ACME/Wile E. Coyote fame will do it. TIA!
Old Oct 26, 2014 | 07:33 PM
Agree'd Erik. This is the first one I've scene or heard of. I wouldn't get our panties in a bunch quite yet. Check out what ya got and if you don't use a hammer/punch/drift you are probably fine.
But by all means, get yourself an aftermarket shock if you can afford it. The benefits are great!!
Old Oct 27, 2014 | 06:16 AM
cybercarl's Avatar
That's my thoughts exactly, I don't mean to panic everyone. Just want to bring it to peoples attention as another area to check/keep an eye on and also bring it to attention to those not in the know, not to use a hammer. That could only weaken it and cause problems over time IMO.
Personally I'm going to put an aftermarket shock on mine as I have something in mind already. This has just been the final push to get it fitted. Upgrade opportunity LOL
Old Oct 27, 2014 | 07:58 AM
PERFECT,, well said... and thanks for the reminder
Old Oct 27, 2014 | 05:19 PM
CrankenFine's Avatar
If someone was worried about a sudden failure they could put on a hose clamp as a reinforcing mod.
Old Oct 27, 2014 | 05:58 PM
I am going to go on record and call that a one-in-a-million failure. Most likely due to abuse of the shock and/or overloading.
Its a showa shock right? How many shocks you figure showa made? How often does this happen?
Case sovle-ed.
Old Oct 27, 2014 | 06:30 PM
Sovle-ed indeed.
Old Oct 28, 2014 | 07:28 AM
thedeatons's Avatar
Lol
Randman
Dec 4, 2009 01:22 AM
CNI Dawg
Feb 1, 2007 08:39 PM
calitoz
Nov 6, 2006 02:44 PM
phsum07
Aug 14, 2006 07:42 AM
Kitch
Jun 28, 2006 09:00 AM
