rear cylinder missfireing
Old Dec 11, 2012 | 04:19 PM
peter lynch's Avatar
peter lynch is on a distinguished road
hi guys as above, when out on bike, could be any gear/rev range,sometimes the back cylinder misses a beat she fires unburned fuel back up the carb? any ideas? thanks
Old Dec 13, 2012 | 07:46 AM
VeeTR's Avatar
VeeTR is on a distinguished road
Its a common Storm thing so get used to it,there are a few things you can do to make it less of an issue but even then you will always get the occasional cough from the motor.Set your TPS,check valve clearances and balance the carbs will help somewhat
Old Dec 13, 2012 | 02:06 PM
THANKS for the reply but TPS? What does that mean, valve clearance checked and carbs balanced, if u get back to me, one more thing, she also wont hold a constant trottle? any idea r is that a storm thing too, thanks
Old Dec 13, 2012 | 03:52 PM
VeeTR's Avatar
Ok well thats a bit more of an issue then the usual cough through the airbox.With such little information its very hard to be exact...you could have a spark,fueling and/or compression problem.Are you sure its the rear cylinder?? Check your plugs first and put a pic of them up,they may give a clue to the problem.Has there been any work carried out recently?
TPS=Throttle Position Sensor
Give as much info as you can so it can be narrowed down somewhat to the likely culprit
Old Dec 15, 2012 | 02:19 PM
ok here goes, about 3 mths ago front cct let go, left her with a lad to repair[same lad has 2 storms] work done 2 new ccts camchain valves[front] when i go the bike back it did not feel the same so i went back to him, he checked timing, balanced carbs etc, but she is not the same bike she was. before the breakdown i could not fault her, hope enough info here, ps plugs dry
Old Dec 17, 2012 | 04:51 PM
VeeTR's Avatar
Ill Pm my number,if your up around Dublin at all I can take a look
clac
Aug 24, 2011 09:49 PM
motogomojo
Jul 12, 2011 10:00 PM
driven
Dec 7, 2008 05:09 AM
Kendrick
Oct 11, 2008 04:10 PM
viperkillertt
Apr 7, 2007 09:03 PM
