rear cylinder missfireing
hi guys as above, when out on bike, could be any gear/rev range,sometimes the back cylinder misses a beat she fires unburned fuel back up the carb? any ideas? thanks
Its a common Storm thing so get used to it,there are a few things you can do to make it less of an issue but even then you will always get the occasional cough from the motor.Set your TPS,check valve clearances and balance the carbs will help somewhat
Originally Posted by VeeTR
(Post 346137)
Originally Posted by peter lynch
(Post 346154)
THANKS for the reply but TPS? What does that mean, valve clearance checked and carbs balanced, if u get back to me, one more thing, she also wont hold a constant trottle? any idea r is that a storm thing too, thanks:confused:
TPS=Throttle Position Sensor Give as much info as you can so it can be narrowed down somewhat to the likely culprit |
(Post 346160)
Ok well thats a bit more of an issue then the usual cough through the airbox.With such little information its very hard to be exact...you could have a spark,fueling and/or compression problem.Are you sure its the rear cylinder?? Check your plugs first and put a pic of them up,they may give a clue to the problem.Has there been any work carried out recently?
(Post 346214)
ok here goes, about 3 mths ago front cct let go, left her with a lad to repair[same lad has 2 storms] work done 2 new ccts camchain valves[front] when i go the bike back it did not feel the same so i went back to him, he checked timing, balanced carbs etc, but she is not the same bike she was. before the breakdown i could not fault her, hope enough info here, ps plugs dry
