RC51 & Superhawk - Gear vs. Chain driven cams
Old Nov 15, 2011 | 10:50 AM
Matt_Hawk's Avatar
Wild Man
Which one is a better cam drive?
1) The RC51 gear driven cam
2) The Superhawk chain driven cam
Old Nov 15, 2011 | 10:57 AM
The answer is 42......
With gear driven cams you have more accurate cam timing but you have more spinning mass to deal with.
Chain drive, not quite as accurate as gear driven cams but much lighter.
So they both are good and both have their applications.
Old Nov 15, 2011 | 11:04 AM
jay956's Avatar
The gears also make noise. Some like it, I am one. Your making me miss my 93 VFR.
Old Nov 15, 2011 | 11:31 AM
Chains: cheaper to produce, less longevity, possib. of CCT failure
Gears: more expensive, more durable, more longevity
Old Nov 15, 2011 | 12:06 PM
comedo's Avatar
It's a Norton Manx vs. a G50 Matchless question. On the street, there's no significant difference. Otherwise +1 to everyone else who has responded.
Old Nov 15, 2011 | 12:52 PM
davidka's Avatar
Gears=no way to adjust head squish. At least has been cited as a limitation to the VFR's engine modification possibilities.
Side question, is it common to alter the VTR's compression? Done with pistons only?
Old Nov 15, 2011 | 06:16 PM
dehning's Avatar
dehning is on a distinguished road
Cool
I have a '99 VFR800 and I love the gear driven cams, they are noisier, but they are a purposeful noise.
I assume the central part of the gear that transfers the force from the crank to the cam doesn't have to deal with any torque, and so can be made pretty lightly with lots of excess metal removed. Plus there is no need for Cam Chain Tensioners or the chain for that matter. With that in mind I'm going to go out on a limb and say that I'm pretty sure gear driven cams are not much (if any) heavier than chain driven ones.
Old Nov 15, 2011 | 06:27 PM
So Mike, I see you're a Douglas Adams fan as well.
Well for a street bike, is there really any other answer....
Though I do like the sound they make but then I like the straight cut primary gears on a VTR also and how many people ask about that noise....
Well here is a RC51 gear drive:
Honda, ATV Parts, Scooter Parts, Motorcycle Parts,CRF,CR,MX Parts, Goldwing parts
You can see it takes 3 gears to get from the crank to the cams. Then you also need the 2 plates they mount in and also the bearings they run on. So yes it is much heavier than a comparable chain driven cam set up.
Though if you are spinning high RPM (and a VTR's meager 10.3K rev limit really isn't all that high) they are the only way to go.
Old Nov 15, 2011 | 06:45 PM
One of our talented machinists needs to develop a drop in gear driven cam setup for the VTR.
Old Nov 16, 2011 | 05:41 AM
dehning's Avatar
That would be cool. Of course there've been gear drive conversions for small block Chevy's for decades.
I don't think it would fit
Old Nov 16, 2011 | 08:37 AM
Well... You'd need a bigger top end on the engine... And bit of goop to seal the edges, but other than that it's more or less a fair bolt on mod...
Serousily though... Now you guys got me thinking... And that's usually a bad thing... I have a VFR engine somewhere, whom somebody tried running without oil... The cam gears in that will have to go on a field trip I think...
Old Nov 16, 2011 | 08:51 AM
FWIW, some companies (like Suzuki on the TL/SV 1000 engines, for example) use a hybrid chain and gear system, the benefit being a more compact head.....
Old Nov 21, 2011 | 03:01 PM
Matt_Hawk's Avatar
Wild Man
...or you can install these HRC billet gear drive units and lightweight rods.
No chain lash. No slight timing retardation. Just a positive exact time. No worries forever.
I'll let you know.
Edit: Now I need some block off plates for the CCT holes. Hmmm.....
Attached Thumbnails RC51 & Superhawk - Gear vs. Chain driven cams-billet-cam-drive.jpg   RC51 & Superhawk - Gear vs. Chain driven cams-valvetrain.gif
Old Apr 30, 2012 | 03:29 AM
Jester666's Avatar
Jester666 is on a distinguished road
I'll let you know.
I just asked about gear driven cams on the UK forum and then came across this old post.
Anyone done it?
Old Apr 30, 2012 | 03:33 AM
karlosvtr's Avatar
karlosvtr is on a distinguished road
Anyone done it?
god damn! good find!
Old Apr 30, 2012 | 06:46 AM
HRCA#1's Avatar
Anyone done it?
I didn't see a link there.
Old Apr 30, 2012 | 07:08 AM
He may just be talking about Matt_Hawk's post above it...
Old Apr 30, 2012 | 09:28 AM
Dan Cronin's Avatar
Well if you are going to change the valve train completely anyway...
CSRV vs. Poppet Valve - Coates International Ltd.
Old Apr 30, 2012 | 01:43 PM
maniac2313's Avatar
maniac2313 is on a distinguished road
I'll let you know
Where did you get these? How much were they?
Old Apr 30, 2012 | 01:44 PM
maniac2313's Avatar
Where did you get these and how much?
Old May 23, 2012 | 03:34 AM
karlosvtr's Avatar
they look like sp1 / sp2 cam gears except HRC ones. i think this would work since the firestorm has the two random bolt holes in the head that bolts the periphery to the block. i think they could be used to bolt down the cam gears. then all you would need to do is rotate the inlet cam 180 degrees. job jobbed
Old May 23, 2012 | 08:48 AM
Yes those are HRC parts that are not made anymore, so if you have to ask how much..... you should know the rest
WordTooYoMamma
Jul 9, 2015 08:56 AM
NZSpokes
Apr 26, 2014 09:21 PM
mikstr
Dec 15, 2011 04:36 PM
msethhunter
Sep 3, 2011 06:28 AM
Tonyizcool1
Jul 28, 2008 10:34 AM
