Radiator fluid change
Old Jan 27, 2008 | 12:58 PM
mikecronis's Avatar
mikecronis
I'm at 9k+ miles now on a 2005 and was wondering when one should change the radiator fluid? One guy told me every season. Opinions?
Old Jan 27, 2008 | 01:48 PM
lrrs195's Avatar
swinging member
lrrs195 is on a distinguished road
I change mine every two years. I also use water wetter.
Old Jan 27, 2008 | 03:06 PM
marmaladedad's Avatar
Hmm?
I put in WW too. I flush mine out every 4-6 months.
Old Jan 28, 2008 | 08:51 AM
mikecronis's Avatar
mikecronis
I lost my service manual .pdf file. Where is the bolt I need to drain the fluid? Thanks.
Old Jan 28, 2008 | 10:05 AM
Duck007's Avatar
Drain bolt is on the front side of the front cylinder, just above/behind the hose that connects the two radiators.
Old Jan 28, 2008 | 10:14 AM
FL02SupaHawk996's Avatar
Fastest Color
I changed my at the 16K service and it really needed it, so doing it at 9K would be even better.
I use WW too and 50:50 anti-freeze and distilled water solution and make sure the anti-freeze is silicate free...
The bolt is on the front cylinder/case and if I remember right it's behind/under the oil cooler. When I drained mine I took the lower hose loose from both radiators and opened the drain plug that way you get it all out for sure...
Old Jan 28, 2008 | 05:00 PM
Thumper's Avatar
I use "Engine Ice" as it still gets pretty cold here in TN and the garage is not heated. I occasionally run Red Line WW and Distilled water, but usually only for a track day when it is required. I think WW is more effective and better cooling, but i don't won't a busted block due to freezing.
http://www.engineice.cc/products.html
Engine Ice protects from freezing down to -27 degrees F.
I Usually do change every other riding season.
Old Jan 28, 2008 | 08:57 PM
mikecronis's Avatar
mikecronis
Yeah, I heard Engine Ice is good stuff, better than Redline's Water Wetter (which I've been using).
Old Jan 28, 2008 | 09:39 PM
I run evans cooling water free coolant; they say it will run 10-15% cooler than anything else & lasts as long as the bike. Even if it won't live that long, we all neglect the coolant so I figure its safer by alot. It sure isn't cheap though.
MikeMcW
Aug 11, 2011 02:22 PM
Letsrideinsc
Dec 15, 2010 06:21 AM
justinity
Sep 19, 2010 04:05 PM
merlyn
May 23, 2009 01:38 PM
HawkRider98
Sep 10, 2008 09:07 AM
