quit running after raid storm
Old May 7, 2011 | 10:03 AM
lavlamp's Avatar
lavlamp is on a distinguished road
quit running after rain storm
Hey guys i got stuck out in a flash flood, stuck under an overpass an hour out of the city all night. When i went to go start the bike (it was still raining) the bike was soaked and would turn over but not start.
I trailered the bike home and have it apart now, spark plugs are replaced but it seems to have no spark. where should i go from here?
Thanks guys!
Old May 7, 2011 | 10:32 AM
bass4dude's Avatar
bass4dude is on a distinguished road
how high did the water get up?
If it got up to the point where it could go down the exhaust pipes you may have a problem.
Do you have any other electrics when you start the bike? Did you check fuses?
And it's realllllllllllly not a good idea to be working on the electrical system of any motorized vehicle or charged piece of equipment while it's raining.
Old May 7, 2011 | 01:02 PM
kai ju's Avatar
Stuck in the rain
Happened to me as well, not as bad as yours but the bike still died.
Turns out that the fuel tank breather hose gets full of water and prevents fuel from flowing into the float bowls.
Open the gas cap and see if the bike will run. If it does, take the fuel tank breather hose and cut it on a diagonal so water won't get sucked up into the hose.
You say it 'seems' to have no spark. How did you check for spark ?
Old May 7, 2011 | 02:26 PM
lavlamp's Avatar
water under the overpass didnt get up past 3 inches where i was parked so it wasnt too bad. I left the bike there and hitchhiked into town since it wouldnt start, then towed it back the next day and i am working on it in my garage, nice and dry!
Old May 7, 2011 | 02:29 PM
lavlamp's Avatar
I tested for spark by putting the cap to metal, and nothing for front or back. ive tried starting it with the gas tank open and unfortunitly no luck
Old May 8, 2011 | 04:01 AM
CrankenFine's Avatar
If you mean the cap at the end of the spark plug wire, you should insert the spark plug before testing, and then holiding by insulation on cap, press the threads against engine metal and observe the spark gap while cranking. Be sure the kill switch is on. (I've confused myself with that part!)
Old May 9, 2011 | 09:14 PM
fred's Avatar
Mid-level Member
fred
heh. good point. i've drained a battery before realizing the sorry truth.
Old May 19, 2011 | 09:17 PM
lavlamp's Avatar
ha yeah i checked to make sure kill switch was not on, im sure everyone has done that before! will try what you said when i finally get home from work tomorrow, thanks
smokinjoe73
Nov 11, 2012 03:07 AM
8541Hawk
Aug 29, 2010 10:30 AM
HRCA#1
Dec 30, 2008 08:19 AM
sam0182
Oct 18, 2007 11:20 AM
RVO27
May 13, 2005 11:00 AM
