quick question, coolant leak
Old Mar 9, 2014 | 10:58 AM
scottiemann's Avatar
So Im finally getting my bike back together so I can ride after over a year...
Over the past year everything has been cleaned thoroughly and rebuilt with new gaskets and hoses etc...
While running it yesterday (idling) I have discovered coolant seeping from the bottom hose connection of my right radiatior... today I tightened up those clamps and a few others and after running there seems to be seeping out of other radiator connections on both sides...
as I have replaced all hoses and clamps I have determined this to be caused by too much pressure in the cooling system. However, when I remove the cap and press on the valve with some pressure it moves...
has anyone ever had an issue with a radiator cap becoming stiffer over time? or is there something else I should be looking at before I get raped at the stealership for a new cap?
BTW I have searched for threads involving this situation and come up with nothing, so if there is one out there please send me a link...
Thanks ahead of time for all your help
Old Mar 9, 2014 | 11:42 AM
new developments... tightened up a few more connections and freed up a minor clog in the hose going from the rad to res, that only took blowing through it with slight force...
and no leaks as of right now, I will be keeping an eye on it but the question about the cap still stands...
Old Mar 9, 2014 | 01:35 PM
Wicky's Avatar
re Cap. Keep searching there's a thread or three that mention a pattern (i.e chepaer off the shelf) radiator cap.
Old Mar 9, 2014 | 01:54 PM
CrickiKaze's Avatar
CrickiKaze is on a distinguished road
Schnitz Racing(spelling?) sells a higher pressure cap, think its 1.5 bar(???) let me find it.
Old Mar 9, 2014 | 01:57 PM
CrickiKaze's Avatar
Schnitz 1.6 Bar Radiator Cap
Old Mar 9, 2014 | 02:37 PM
Wicky's Avatar
1st search result in Knowledgebase > https://www.superhawkforum.com/forum...ference-26656/
https://www.google.com/#newwindow=1&...r+cap&safe=off
Old Mar 9, 2014 | 06:19 PM
I appreciate the prompt responses... i seemed to have fixed the leak for the moment but will be keeping a close eye on it.
Ill probably invest in a schnitz one a have some spare change in a month or so seeing as i wont be riding much til then (still in the 20s and 30s with he occasional warm day)...
Besides, schnitz is still cheaper then oem :P
mkimber
Jan 13, 2008 06:18 PM
j_frank
Apr 28, 2007 11:40 PM
EngineNoO9
Oct 20, 2006 09:01 PM
EngineNoO9
Dec 21, 2005 06:10 AM
faz
Jul 29, 2004 10:58 AM
