Question for those who have done "comfort bar" mod
Old Apr 3, 2009 | 07:18 PM
HawkFanatic's Avatar
HawkFanatic is on a distinguished road
So, my sister got me a new Pro Taper bar for my CRF450 (Pastrana model)which I installed, and now I have my old bar a Pro Taper oversize Carmichael model.
I would like to do this mod with this Pro Taper Bar.
These are my questions;
#1) Has anyone done this mod with oversize Pro Tapers?
#2) I am assuming you just drilled two holes though the top triple clamp, this shouldn't be hard as I have access to a machine shop - just want to make sure.
#3) Have any of you noticed vibration problems? I was going over this with my local Honda dealer and he said Harley makes a great dampening filler piece (can't remember what it was called). You basically drill the hole bigger than the bar clamp bolt, put the rubber Harley dampener in THEN put the clamp bolt through. It sounds like a good idea, I just wonder if it is truly necessary.
Thanks
-HF
Old Apr 3, 2009 | 07:28 PM
cliby's Avatar
#4) I heard this mod will make my dick bigger, is this true?
Thanks
-HF
1) yes, on stock and other front ends
2) yes, just get the right risers
3) no. I used bar end weights and its as good as stock. the handlebar snake might work but some fat bars have very narrow diameters at the end and might not fit.
4) I suppose, if you really need it.
here is one thread
https://www.superhawkforum.com/forum...ghlight=fatbar
Old Apr 3, 2009 | 07:59 PM
FL02SupaHawk996's Avatar
Fastest Color
+1 Bill is right
here's another thread:
https://www.superhawkforum.com/forum...superbike+bars
Sorry to hear that you have a little problem in #4
Old Apr 4, 2009 | 01:03 AM
maverick's Avatar
That's not even necessary... All you have to do is put a rubber washer under the risers and there will be almost no vibration at all.
slabm7
Apr 2, 2010 04:39 AM
Gerrit
Mar 13, 2009 07:52 PM
andy9743
Mar 4, 2009 08:47 AM
cal2az
Sep 28, 2008 09:57 AM
andy9743
Sep 6, 2007 12:21 PM
