Poor gas milage.
Old May 27, 2015 | 06:30 PM
gti52's Avatar
gti52 is on a distinguished road
Poor gas milage.
I have only had my superhawk for a few weeks and seem to be getting very poor gas mileage. The first tank I put in was 3.4 gallons and I went 76 miles before the fuel light came on. The second tank went 62 miles and took 3.3 gallons. That equates to 18.8 miles to the gallon. My 3/4 ton pick-up gets 18 miles to the gallon! I know superhawks are not known for great mileage, but this is ridiculous. Anyone else dealt with this kind of poor mileage?
Old May 27, 2015 | 06:46 PM
Big_Jim59's Avatar
Is it running good otherwise? Does is smell rich when it's running? Backfire a lot on the overrun? Does it start easily with no choke.
I would check the choke (enrichment valves) and see if they are seating.
Old May 27, 2015 | 07:06 PM
scottiemann's Avatar
if its smelling super rich check your fuel screws as well
Old May 27, 2015 | 08:49 PM
gti52's Avatar
It does seem to backfire on over run. It will start without the choke if you give it some throttle. But will occasionally backfire when starting. I haven't noticed that it smells rich when running though.
Old May 28, 2015 | 01:46 AM
NZSpokes's Avatar
Check your oil to see if it smells like gas.
I get 120 miles before the light.
Old May 28, 2015 | 04:47 AM
AndyMX47's Avatar
The choke fittings on my bike were broken, resulting in the rear choke (enrichener) circuit being partly open - that was one problem.
My bike also had overly rich jetting in the needles (Dynojet needles) that I'm slowly leaning out.
My gas mileage prior to fixing the choke fittings was about 28-30 though, never low 20's, and I ride the crap out of it in the mountains - no highway.
I think you should be at least 30 mpg on a stock bike with stock jetting.
Old May 28, 2015 | 08:03 PM
gti52's Avatar
OK, no gas smell in the oil. But the exhaust does seem to smell rich, the wife even mentioned it today when she entered the garage a couple of minutes after I got home from work. The bike might have a jet kit in it. It does have aftermarket pipes on it. My choke doesn't seem to do anything, I'm wondering if it could be stuck open? But I would think that might make it run poorly once it is hot, but it seems to run ok once warmed up.
Old May 29, 2015 | 07:58 AM
CrankenFine's Avatar
Do you have stock gearing? If a previous owner changed from stock and did not install a speedo healer you maybe going more miles than the odometer indicates.
Old Jun 8, 2015 | 01:32 PM
gti52's Avatar
Well I tore into the carbs today. Pilot jets were 55s in both carbs, and the mains were 185 front and 190 rear. Seems pretty fat to me, even with the full exhaust and filter. especially the pilots. New jets are on the way. Hopefully this will fix the milage problem.
Old Jun 16, 2015 | 10:13 AM
AndyMX47's Avatar
Remember to check under the needles to see if they are shimmed as well - stock there should be one thin washer between the needle and slide - about 0.018" thick.
Wow your jetting was super fat - can't believe it wasn't fouling spark plugs, which, you should probably replace while you have it apart.
Old Jun 18, 2015 | 01:49 AM
NZSpokes's Avatar
Thats very big for a stock airbox. Is the filter a stock one. I would start with Hawks carb setup.
Old Jun 18, 2015 | 06:06 AM
gti52's Avatar
What are the stock main jet sizes? I haven't been able to find this info anywhere.
Old Jun 18, 2015 | 06:22 AM
comedo's Avatar
175 front and 178 rear except at higher altitudes.
Old Jun 18, 2015 | 11:33 AM
NZSpokes's Avatar
And 45 idles.
Old Jun 18, 2015 | 11:57 AM
AndyMX47's Avatar
My bike with two brothers mufflers, stock intake and stock air filter is running:
178f, 180R
stock needles with one #4 brass washer under each - about .08" thicker than stock - probably negligible
45 pilots
2 1/2 turns out on the fuel screws
stock slide springs
extra lift hole in the slides (much debate about this - I tried plugging one front lift hole, running two stock lift holes, and running the extra hole)
Long story short - stock jetting isn't bad, but a little lean on top (according to the dyno I could have gone one more main jet size richer to 180F 182R for maximum power)
Runs fantastic, great throttle response, gets from 30 to 35 mpg, depending upon how I ride.
Old Jun 18, 2015 | 01:19 PM
I really haven't heard any debate about the lift holes.
I have just heard (from Roger@Revolution, Bob@Moriwaki and Dan@Erion who were all doing factory racing development on the VTR) that 3 lift holes does not work and causes issues.
DynoJet is the only one that thinks it is a good thing and that is because they do it to all their jet kits and it is just to get the carb off the pilot circuit quickly....good for I4 but no so much with a twin.
So glad you got it to work though I wouldn't expect it to work on another bike.
Old Aug 27, 2015 | 04:39 AM
Dunlop's Avatar
Dunlop is on a distinguished road
After reading this post I am I contacted Jack Flash about the brass choke fittings and fuel screws
I have a 1998 VTR 1000 and I am currently getting 26mpg.
I had to clean my carburetors 3 times before I realized that the gas tank was contaminated, during that time I purchased the Ultimate kit from the carbjet kit website which consists of 180, 185 main jets, 48 pilot jets and 2 shims per carb $26. I recommend this website if you need to order jets.
I turned out the fuel screws to 3 turns, I know too far out. My bike has the stock air box and filter fitted with jardine slip ons. The bike runs terrific and the throttle is spot on but at idle it constantly stumbles around. I know the choke fittings are weak and I should have replaced them when I had the carbs off. I am hoping by fixing the choke fittings and turning the fuel screws in ½ a turn I will be able to get closer to 30mpg.
I will post my results, maybe the info will help others.
Old Aug 27, 2015 | 10:28 AM
AndyMX47's Avatar
You may find out your a little rich even with those settings.
Lately my gas mileage has ranged from a low of 30 to a high of about 35. I think I am slightly lean on the needles - might try an additional shim - I would have two shims under the needles if I added one.
Realize the fuel screws primarily affect idle performance. I wouldn't be afraid to try 45 pilot jets and lean the fuel screws out a little.
Old Sep 4, 2015 | 01:04 AM
bird-rider's Avatar
bird-rider is on a distinguished road
May be a tune up could solve the high gas consumption. Make sure to synchronized the TB.
Old Sep 20, 2015 | 07:22 AM
Dunlop's Avatar
I finally fixed my MPG problem. It turns out that 3 shims under the already tapered needle were way too much LOL oops.. I am back at 35 MPG
twist
Sep 18, 2014 07:51 AM
wsharpman
Jun 25, 2012 10:03 PM
meanhawk98
Mar 13, 2012 06:52 PM
Lefin102
Jul 10, 2007 04:50 PM
Verne
Jun 25, 2006 05:22 PM
