Please help! This is my first Sportbike!!!!
Old Jan 30, 2008 | 05:52 PM
Reba's Avatar
Reba is on a distinguished road
Here is my problem. I bought a 99 SH from the Honda shop with the CCTs bad. Well it bent and broke a rear valve. Yesterday I put in the head, done the timing and everything went together smooth. It purrs like a kitten until you hit 6-7000 rpms then it wants to cut out. I can shift into another gear and it quits. This is my first sportbike and I am doing the work myself. What could this be? Any help would be appreciated!
Old Jan 30, 2008 | 06:10 PM
seems that a cam may be a tooth off. Who did the work on the head... do you know what was done exactly?
Old Jan 30, 2008 | 06:17 PM
Reba's Avatar
I bought a head from someone who's CCTs went bad in the front. He sold me his rear head. I just installed it. Per the manual the timing is perfect. I have checked that so many times until I am going crazy.
Old Jan 30, 2008 | 08:52 PM
Brian A's Avatar
Carb problem maybe?
Maybe a clogged/partial clogged main jet(s)?
Old Jan 31, 2008 | 06:19 AM
Reba's Avatar
Just checked that. The jets are fine. It has me baffeled.
Old Jan 31, 2008 | 06:30 AM
Cleveland's Avatar
Post Whore Junior
I hate to keep harping this issue.. but a vibrating kickstand switch will make the bike cut out like that.. when the kickstand is down, the bike wont run in gear (even with clutch pulled).. I've personally seen this as an issue.. the vibrations @ WOT or high rpms will cause the kickstand switch to turn on and off.. making the bike seem to studder.
Old Jan 31, 2008 | 06:31 AM
Cleveland's Avatar
Post Whore Junior
I went through the bike for weeks.. carbs, timing, jets, electrical.. never found a problem.. then ran across this by accident.. been passing it along ever since..
Old Jan 31, 2008 | 10:33 AM
Reba's Avatar
I will look at that now. I'll let you know. I think it might be the throttle position sensor......... testing that now in the garage.
Old Jan 31, 2008 | 10:49 AM
Reba's Avatar
Could it be that my ccts are to tight?
Old Jan 31, 2008 | 10:53 AM
who says its myth
that VTR CCTs go or the frequency is overstated? Did u instal APEs? How did u set them, there is tons on that?
BTW, sidestand switches can cut out in the rain too!
Old Jan 31, 2008 | 11:31 AM
Reba's Avatar
Yes, they are apes...Read up on them before I installed. I installed per a forum on here. It was very detailed. I realy don't think that is it but right now I have my laptop in the garage trying to diagnos. Any help would be appreciated.
Old Jan 31, 2008 | 01:43 PM
FL02SupaHawk996's Avatar
Fastest Color
Reba, when you reinstalled the tank did you hook-up all lines correctly? Check the stop-**** nipple that you put the vacuum tube on to make sure it's right cuz sounds fuel related to me
Old Jan 31, 2008 | 01:46 PM
Try using the choke as a troubleshooting tool. Pull the choke out a little bit and ride the bike. If the condition gets either better or worse then it's most likely a carburetion problem - better and you're too lean, worse you're too rich.
Also, do a search on "PVLIR". This is pretty common.
Old Jan 31, 2008 | 01:47 PM
FL02 beat me to it by 3 minutes. Still, do the choke check.
Old Jan 31, 2008 | 01:54 PM
Fastest Color
Reba, you're in good hands with Greg
RC
Old Jan 31, 2008 | 02:36 PM
Reba's Avatar
Okay so here it what I have found so far...... I fixed the choke position.....my error.... black smoke is now gone. Tried testing the throttle control sensor but I am not getting the correct readings....so I went back to the ICM and everything seems to be fine back there. Does this mean the TCS is bad. I am about at my wits end with this thing!!!!! After I fixed the choke I got it up to 9k RPM but had to gradually get there. Still cannot hammer down on the throttle or it starts breaking up sooner.
Old Jan 31, 2008 | 03:03 PM
If you think it's the TPS just diconnect it and ride it. The ECU will not include the sensor's lack of signal in the map, and the bike should run just fine.
Are you absolutely positive you don't have the vacuum line attached to the bottom of the petcock?
Old Jan 31, 2008 | 03:06 PM
You checked PVLIR? (I always go easy first..) Also how far off is TPS?
Old Jan 31, 2008 | 03:17 PM
Reba's Avatar
Greg, I did remove the TPS and yes it runs just fine....that is .... until you hit 7k rpm and the hard throttle and if not hard on the throttle you can baby it up to 9k rpm. And please forgive me but I am new at theis.... What is the PVLIR? As far as the gas tank goes all lines are hooked up correctly. The samll hose will only fit on the back one. Again thanks so much. This is the first project I have done like this.
Old Jan 31, 2008 | 04:09 PM
So with the choke on it ran worse? Have you checked your air filter?
Old Jan 31, 2008 | 04:31 PM
Reba's Avatar
Yes, when I pulled the choke out it ran worse. The air filter seems fine. What else can I check? With the TPS out it runs but you still can't crack down on the throttle without it breaking up bad.
Old Jan 31, 2008 | 05:09 PM
Sounds like you might be running too rich. How about pulling the air filter and trying to ride it?
I'm inclined to suspect one or more coils are breaking up but if you're saying that this troubleshooting has resulted in inconsistent running conditions then it's probably not that.
Have you been into the carbs at all? It is the same at idle as it is under load (breaking up when opening throttle)?
Old Feb 1, 2008 | 08:00 AM
MudSwettinGears's Avatar
MudSwettinGears is on a distinguished road
Reba
PVLIR is "Petcock Vacuum Line Inadvertant Relocation"...I ran into the same problem this week after I had some bodywork done, tank repaired, etc. I assumed the guy who put the bike back together would know where the vacuum line is supposed to go, I was wrong. Beat myself up trying to figure out what was wrong with it. Looked throughout the forum and found that a bunch of folks had the same issue...vacuum line DOES NOT go on the nipple located on the bottom of the petcock, it goes in the rear of he petcock. Don't know if this solves your problem, but it's a start!
Old Feb 14, 2008 | 07:34 PM
Motohead's Avatar
Motohead
Double check you cam timing doing both cylinders per the manual. I'm betting you have one of the cylinders timed on the wrong stroke. Been there...nice and torquey, hits 7k and falls on its face.
Moto Man
Aug 27, 2009 11:44 AM
mattvdsande
Mar 16, 2009 11:12 AM
74stingray
Jul 23, 2008 03:56 PM
jbeber
Jun 7, 2008 02:45 PM
F1 Fan in Nascar Land
Mar 20, 2008 04:01 PM
