Please Help Im not a Tech
Old Jul 12, 2007 | 09:04 AM
F1 Fan in Nascar Land's Avatar
F1 Fan in Nascar Land is an unknown quantity at this point
I was wondering if there is a link to a how to do with pictures for doing an oil Change I will search but last time a did a search for Oil Change there are a ton of hits so it took forever before I quit it.
Thanks guys
Old Jul 12, 2007 | 09:32 AM
gboezio's Avatar
No pictures but it's quite easy. The plug is the lower bolt on the side stand side of the oil pan(engine), unscrew, drain (in a bucket, then in the empty oil container), put back plug.
Oil filter, remove the gray plastic protector with an allen wrench and the 10 mm bolt with a wrench, unscrew the oil filter with the bucket underneath, dip finger in oil to lube the rubber O-ring of the new gasket and tighten by hands until fairly tight or until contact+half turn, put back plastic thingie.
New oil, open the fill cap pour 3 1/2 liters in there, put cap, start engine, check for leaks, don't rev the engine (take a while to get oil pressure), stop engine, put bike straight if not already, adjust to 3/4 to full of both marks in oil window (clutch side).
Options, you can beat the crap out of the engine to dislodge sludge before, I do sometimes just to provide a good excuse to do what most people around me think is stupid. Don't put anything else than motorcycle engine oil or you may regret it.
Don't start an oil thread on this board and please dispose your oil in a responsible way.
Old Jul 12, 2007 | 09:50 AM
gboezio's Avatar
Well here's one I was bored
Old Jul 12, 2007 | 11:56 AM
So the Oil Plug Bolt is on the side facing out cause my friend said he never saw one before.
Old Jul 12, 2007 | 12:10 PM
StoneJrW's Avatar
StoneJrW is on a distinguished road
Yep thats it.
NZSpokes
Oct 29, 2014 08:26 AM
lynchie
Apr 23, 2011 01:42 PM
mcadena89
Jun 3, 2009 12:04 AM
mattvdsande
Mar 16, 2009 11:12 AM
