Please educate a newbie about brake lines
Old Jul 30, 2009 | 11:33 AM
Redone's Avatar
Redone is on a distinguished road
Smile Please educate a newbie about brake lines
I spent an hour searching and reading old posts, but they're not directly on point for me.
I see mostly 2-line kits. Do these eliminate the upper hose and the junction block? Are there any reasons eliminating that's a bad idea? Do you have to secure the new brake lines differently?
One of the reasons I'm doing this is to get a bit more length to pick up the helibars a bit more. Do aftermarket lines typically come just long enough? It seems to me a manufacturer would add a bit, just because. Someone posted that you can order Galfers +1 or +2. Are there other brands that do that, or, if I want +1, are Galfers the way to go?
Thanks.
Old Jul 30, 2009 | 11:46 AM
Syclone's Avatar
Boosted
You can order Spieglers in many different configurations too. If you want, you can get a single line to the M/C, with a double-banjo at the right caliper and a jumper line over to the second caliper. I got the double lines from the M/C in stock length I believe, but you can get +1 or +2 lengths too. As for eliminating the splitter block, there's nothing wrong with that. You will need to secure the lines differently, however.
Old Jul 31, 2009 | 12:10 AM
shayne's Avatar
My advice would be to get the full twin line system, and do away with the splitter. I think this is a better set up. I have seen a lot of bikes with braided lines, and the twin lines feel better to me. Standard length will be fine I think.
Old Jul 31, 2009 | 08:14 AM
Redone's Avatar
Smile
Thanks, all.
Old Aug 4, 2009 | 05:22 PM
MOONSTER's Avatar
Running Spieglers on mine, which came about 3in. longer than stock. If you go to spiegler.com & click on custom brake lines you can get any length you want. Also different bends on banjo fittings.
bigpants
Aug 28, 2013 07:05 AM
74stingray
Jul 23, 2008 03:56 PM
F1 Fan in Nascar Land
Apr 25, 2007 11:43 AM
jaws
Mar 31, 2007 02:49 PM
