PAIR on Dyno?
Old Sep 17, 2020 | 03:14 PM
ACE VenTRa's Avatar
PAIR on Dyno?
Has anyone ever run their VTR on the dyno with the PAIR system intact and then ran it removed? Or, have you ever done it on any bike with secondary air injection? Just curious what you may have noted for a difference in air fuel ration with vs without?
Thank you\
AV
Old Sep 18, 2020 | 06:57 AM
Never thought about this. Since the air injection is after the combustion process and outside of the chamber, I don't see how power would be affected.
But who knows, not me.
Old Sep 19, 2020 | 04:35 PM
ACE VenTRa's Avatar
Not power...AFR. The PAIR is a controlled air leak into the exhaust stream which does show up as a false lean condition. This is why they are disconnected for a dyno run, to allow for a more accurate reading. Now in my case I'm running the PCV directly to the reed valve, this has a similar effect, the only difference being that the air pulled into the exhaust stream is from the crankcase as opposed to the airbox. I've only read of one other person verifying the extent of the lean condition caused by the PAIR system though he did not elaborate other than to say it was excessive at 7k and above...this is consistent with what I saw on my last run, after 7k the AFR trended toward lean. Just curious what others may or may not have seen,
AV
Blackbetty
Sep 20, 2013 02:40 AM
rich.m
May 3, 2010 09:24 AM
finepooch
Apr 18, 2009 03:17 PM
SuperHawkins
Jul 31, 2007 09:34 AM
roadrun_fr
Aug 6, 2005 05:49 AM
