Oil Psi New Motor
Old Jul 1, 2017 | 09:19 PM
Stumpy's Avatar
Oil Psi New Motor
So here is the ?
On a new rebuilt motor filled with oil and the spark plugs out can you turn the motor over with the starter to get oil psi or does the motor need to fire up?
Old Jul 2, 2017 | 12:53 AM
Turn it over with the starter however I doubt if it will spin fast enough to achieve much pressure !
I have an oil pressure gauge on my bike and at idle it runs about 40 psi and at cruising revs averages about 80 psi up to about 7,000 rpm and over that 90 psi.
Hope this helps.
If you have oiled all the new bearings and Camshafts up you should be good to go anyway.
Cheers
Old Jul 2, 2017 | 04:57 PM
Stumpy's Avatar
Thanks float bowl o ring away for parts to finish the carb then I will find out
Jul 17, 2011 07:53 AM
spladle160
Mar 15, 2010 08:42 AM
CNI Dawg
Jan 24, 2008 08:59 PM
EngineNoO9
Oct 10, 2006 07:44 PM
Rollingalong
Apr 20, 2005 04:48 PM
