OK What type of Motor Oil are you using ?
Old Jan 8, 2005 | 08:09 AM
Rollingalong's Avatar
Rollingalong
Every forum needs it a motor oil topic
So what are you guys using these days and ..... why ?
Old Jan 8, 2005 | 08:57 AM
marmaladedad's Avatar
Hmm?
Honda 10W40
I change my oil frequently (every 2 trackdays or 3k miles), so I don't like to spend too much. Honda-branded oil is relatively cheap, so that does it for me.
Old Jan 8, 2005 | 09:34 PM
superbling's Avatar
Re: OK What type of Motor Oil are you using ?
Mobil 1 Red Cap
When I need to run non-syn: Castrol GTX
Old Jan 9, 2005 | 10:23 AM
pickle.of.doom's Avatar
pickle.of.doom
I use the Honda oil too! Good excuse to get to the bike shop
Old Jan 9, 2005 | 02:09 PM
prhenderson's Avatar
Motorcyclenut!
prhenderson
Amzoil
Old Jan 9, 2005 | 09:40 PM
superbling's Avatar
I've been on quite a few boards/lists over the past nearly 10 years and this oil question is the end all/be all of never ending threads. It's nearly religious!
In the VFR world, there's a guy who happens to live just up the road from me (in Texas terms anyway) who analyzes oils/breakdowns for a living. I went searching for his advice but unfortunately the real nuggets in the archives were lost. I did find these two quotes from another thread that I think will suffice. Hope it makes sense. ScootR is the oil guy's name.
I won't presume to speak for ScootR :bow: but I will toss in what I have learned from him in this thread (besides his ribbing on my obsessive oil level checks )
What oil to use is basically a personal decision based on many factors: cost, your budget, your time, your definition of "best protection", etc... For me, it's Chevron DELO 400 HD Diesel oil in 15W-40. $6.42 for a gallon at Walmart. This decision was based on lengthy discussions with ScootR and his feedback backed up with actual data. The DELO performs as well or even better in some cases as the so-called synthetics, though they have their advantages, too. I have nothing against Mobil 1 syns-I have learned that they (15W and higher) are great oils, but the DELO protects as well for a fraction of the cost. I change the oil every 3K miles whether I am running synthetic or dino, so the cost is a factor.
Again, it is entirely up to you. If you really want to go synthetic, the Mobil 1 15W-50 red cap is a great oil, and the Mobil 1 20W-50 is even better according to oil analysis. The cold pour point on both is fine for temps down somewhere below 0, so it should cover you for at least half the year there (I'm in Texas so all year for me).
ScootR-let me know if I have stepped on your toes here...
And here's ScootR's short reply:
Damn ! You guys are good :bow: 60 degrees at nite ain't cold even for a monograde oil. Read your owners manual, the vis chart vs ambient temp is accurate. I won't use lower than a 15W and prefer 50 grades on the upper end. So for me it's 15W-50 or 20W-50's. The 15W-40 HD diesel oils are very good too, I know, I tested them all at work. The 5W-40 HD oils are also good, the syns anyways but I will say they are not as good w.r.t. valvetrain wear as the 15W-40's and the best I've seen to date were a couple pf 20W-50's.
End of thread. Can of worms opened, running for cover...........
Doug
Old Jan 9, 2005 | 10:27 PM
Hmm?
Don't know if this helps anyone, but here's where I next plan on purchasing my oil.
http://www.hondadirectlineusa.com/st...4&ID=508298686
Old Jan 18, 2005 | 06:59 AM
HotStreetVTR's Avatar
HotStreetVTR
Fully synthetic: Mobil 1 for V-Twins
(No problems at all with clitch slippage)
--HotStreetVTR
Old Jan 18, 2005 | 07:00 AM
HotStreetVTR
No problems with "clutch slippage" either.
--HotStreetVTR
Old Jan 18, 2005 | 03:06 PM
faz's Avatar
faz
faz
Mobile1 MX4T - motorcycle specific full synthetic.
OEM filter.
Old Feb 22, 2005 | 07:09 AM
Rollingalong
Mobil now makes their Supersyn in a 10w-40 and it's call Extended Peformance .
I think it will do well in non race conditions and is 23 bucks for a 5quart jug @ Walmarts . They have a 15w-50 version also . It's the same as the red cap 15w-50 but with more boron and calcium n stuff .
I'm not switching from Synergyn and Maxima though . I buy those two at about the same price .
Old Feb 22, 2005 | 08:07 PM
Thumper's Avatar
Castrol R4
Old Feb 23, 2005 | 08:22 AM
AZZKIKER's Avatar
I use the honda high performance GN 40.
Old Apr 11, 2005 | 01:52 PM
BooYeah's Avatar
BooYeah
thought i would bring this back up for discussion
Old Apr 11, 2005 | 01:59 PM
jschmidt's Avatar
jschmidt
Mobil 1 10w40.
Old Apr 11, 2005 | 07:13 PM
BooYeah's Avatar
BooYeah
This si what i went with today.
I have nothing against honda but they make good cars and bikes, where as valvoline almost exsclusively makes oil. So in my mind i think they make a better oil. They say they have done a bunch of research with the clutches and motors of all 4 stroke cycles.
the best
What do you guys think, i think it is the best.
thetophatflash's Avatar
Honda Pro Blend with moly 20w-50. The moly gives a little smoother shifting.
Old Apr 11, 2005 | 07:18 PM
BooYeah's Avatar
BooYeah
my honda dealer said the with moly, is what causes the clutches to slip. Then when he looked it up it said it recomended that as an oil, so i went with valvoline.
Old Apr 11, 2005 | 07:36 PM
superbling's Avatar
Mobil one red cap 15-50w (gets pretty darn hot down here).
Old Apr 12, 2005 | 05:09 AM
cdyer77's Avatar
cdyer77
I usually use Motul but my dealer was out, so I am trying the Honda Hi Perf. GN 40. I put about 80 miles on sunday, seemed ok. I was surprised when I put the oil in though, It wasn't light golden as most oil is when new. It was darker, more copper colored. We'll see how it holds up.
98VTRrider
Dec 20, 2011 12:33 PM
Randman
Feb 14, 2009 08:42 PM
Randman
Aug 26, 2007 09:14 PM
Randman
Mar 30, 2007 05:38 AM
Speed_Demon
Feb 2, 2006 05:52 PM
