Ohlins set up.
Old May 21, 2014 | 01:18 PM
NZSpokes's Avatar
Ohlins set up.
I just picked up an Ohlins for my bike. Will get it in a couple of days.
Anybody got some tips on set up for them?
Old May 21, 2014 | 02:58 PM
jscobey's Avatar
Are you talking about a shock? If sonyoull love it. That's what I have. What do you mean about set up? Install or settings for rebound compression preload...?
I know the stock spring(if you have the HO-701 shock which has 2 remote reseviors) is for about a 150 lb rider so if that's not you then you should change the spring.
Old May 21, 2014 | 04:36 PM
NZSpokes's Avatar
Yes its a H-701. I will probably need to swap the spring. I have a 1000lb one which will probably go in.
Old May 21, 2014 | 04:46 PM
insulinboy's Avatar
Thats a whole lot of spring. I'd think the subframe would bend under that much load
Old May 21, 2014 | 05:08 PM
jscobey's Avatar
Did you get it new or used? I was glad the PO put the ohlins on. I was under the impression. That ohlins discontinued it. Not a lot of guys willing to cough up $1800 for a shock on the VTR although its worth every penny
Old May 21, 2014 | 05:23 PM
NZSpokes's Avatar
Im huge, I likes me beer....
Old May 21, 2014 | 05:25 PM
NZSpokes's Avatar
Came up on the local Ebay for very cheap. It had a full service 200 miles ago. He has receipts. New seals, oil and gas.
Old May 21, 2014 | 06:01 PM
insulinboy's Avatar
They did discontinue it, but I think they had one or two left in the warehouse. It was a little bit ago that I read that however
Old May 21, 2014 | 06:47 PM
Do you know how to properly set sag?
Old May 21, 2014 | 08:47 PM
thedeatons's Avatar
Yep, i posted about the ohlins stock/inventory issue.
James
Old May 21, 2014 | 10:42 PM
NZSpokes's Avatar
Yup.
It has a 857lb spring on it which will be to light. From what i have read and been told I will be in the 1000lb spring range.
Yes interested in what peoples rebound and comp settings are. Not sure if i will keep the remote preload on or not. Once its set its done.
Old May 21, 2014 | 10:58 PM
NZSpokes's Avatar
Racetech site has me needing a 1150lb spring.
Old May 21, 2014 | 11:04 PM
jscobey's Avatar
have a look through this
http://www.ohlins.com/Products/Owner...M_07241-02.pdf
also this http://www.ohlins.com/Products/Mount...s/MI_HO701.pdf says that the Reb. click should be 14 as a baseline, Comp. click should be 12 as a baseline, and preload of 13mm as a baseline
and why the heck would you take the preload adjuster off? thats one of the nice parts of the shock is that you dont need to get your spanner out for any adjustments...
Old May 21, 2014 | 11:10 PM
NZSpokes's Avatar
Thanks for that.
Weight. Its extra weight thats not needed. I will keep it on to start with but I doubt it will stay long term.
Old May 21, 2014 | 11:20 PM
jscobey's Avatar
how did i know you were gonna say weight....
trust me im all about shaving off any unneeded weight down to the ounces but IMHO its such a valuable part of such a nice shock (one of the reasons they are so pricey) that its not worth ripping off to save a few ounces. Your better off skipping breakfast...
i guess i use it alot and its nice to be able to make quick adjustments at the track (or anywhere) if needed.
if your the kinda person that sets suspension once and never touches it again then fine. IMO the adjusters look cool too. shows off your pricey Ohlins
Old May 21, 2014 | 11:33 PM
NZSpokes's Avatar
Yeah, I get that. We will see. It will probably end up there full time as once its fitted I wont be bothered to remove it.
Old May 21, 2014 | 11:40 PM
NZSpokes's Avatar
How hard is it to fit a shock to them? Any tricks to make it easier?
Old May 22, 2014 | 05:43 AM
sailorjerry's Avatar
It's really not that hard.
All I did when installing my DMr shock was lift the rear of the bike up with ratchet straps from the subframe to get the tension off the swinger, removed the rear header and was able to slide the old shock right out, and the new one right in.
Old May 22, 2014 | 07:30 AM
jscobey's Avatar
Yea its not hard nor complicated. Just time consuming. Hold the back with ratchet straps. Take off the headers and exhaust. Disconnect the linkage. Take off the but at the top of the shock. Pull it down and out. Reverse for the new one. The preload reseviors attaches to the right side passenger peg and the comp damping reseviors straps to the subframe on the left
Old May 22, 2014 | 09:48 AM
CrankenFine's Avatar
I changed my rear shock without removing the header from the engine. You have to fiddle with rear swingarm position up & down but it can be done. GLW new shock.
Old May 22, 2014 | 10:48 AM
+1. Then you don't have to worry about buying new crush washers and such.
Old May 22, 2014 | 11:32 PM
NZSpokes's Avatar
Got it in. Easy as. Finished for the night. Just need to mount the extra bits that hang off it.
It even came with stickers.
filter_jam
Apr 20, 2007 07:49 PM
Randman
Apr 3, 2007 06:11 PM
captainchaos
Sep 20, 2006 05:37 PM
CNI Dawg
Jun 3, 2006 06:03 PM
superbling
May 20, 2006 03:36 PM
