Ohlins front fork springs VTR1000F.
Old Apr 19, 2007 | 10:09 AM
filter_jam's Avatar
filter_jam is on a distinguished road
Has anyone changed the stock fork springs with the Ohlins springs ?
Any change in handling ?
Is it worth doing the change ?
Old Apr 19, 2007 | 06:30 PM
JamieDaugherty's Avatar
I do not have first hand experience with the Ohlins springs, but I can tell you that getting the proper spring rate for your weight will certainly make an improvement in the handling. The rest of the world might be full of 160lb 'average' riders, but here in the land-o-plenty we have a lot of people that weigh much more. I am a good example of that! Honda doesn't want to make special US-only springs if they don't have to, so those of us who wear XL size shirts need to buy different springs if we want to maximize the performance of our bikes.
Old Apr 20, 2007 | 08:30 AM
fundgh's Avatar
As a side note, after doing a comparison on the scale, I have determined that my gear weighs in at 24 lbs. This takes me from an average 165-170 lbs, to 190 lbs geared up. Do you suppose the spring rate is referring to a geared up rider? If this is the case, if the bike is sprung for a 160-170 lb rider, does this mean that they really think that most people riding these bikes are tipping the scale at 140 lbs?
How is the spring rate determined? I bought a used bike and the P/O told me that he had Racetech springs put in it, how can I find out what rate the springs are?
Old Apr 20, 2007 | 08:53 AM
redlinetech's Avatar
redlinetech is on a distinguished road
Always a geared rider.
Old Apr 20, 2007 | 02:19 PM
tommygdbr's Avatar
tommygdbr is on a distinguished road
www.racetech.com I think they ask for your wieght WITHOUT gear.... I might be wrong.......
Old Apr 20, 2007 | 04:06 PM
superbling's Avatar
When I got a wilbers shock, they wanted to know weight with gear, how much my tankbag typically weighed, did I normally have saddlebags mounted, etc.
Don't rule out racetech and sonic springs also.
Old Apr 20, 2007 | 07:49 PM
Spring rate takes both the bike weight and GEARED UP rider into consideration.
Here's how they figure it: The VTR is about 474#, according to Honda, and she carries about 55% of her weight in the rear. Rider is about 75% in the rear too, depending on rider and riding position. Say you're 190# geared up.
474*.55 = 260.7 = 118.3kg
190*.75 = 142.5 = 64.6kg
Proper UNladen sag (without rider) is about 12-15mm. Let's use 15. Laden (rider) sag should be about 25mm. This is 10mm difference. So now in order to get that 10mm sag with the rider, divide the rider weight by the difference between laden and unladen:
64.6kg / 10mm = 6.46kg/mm (Ohlins has a 6.52 so we'll use that)
That's about a 365#/in spring.
So now let's figure out if the bike will have proper unladen sag:
118.3kg / 6.52 kg/mm = 18.1mm
This is more unladen sag than what we want so as you can see we have to add some preload (most springs are preloaded anyway). You could choose a slightly softer spring and add a bit more preload to get correct laden sag, which is probably what I'd do in this case. 6.11kg/mm spring for you. One more thing, I don't know about your bike, but I had mine measured on a calibrated scale with 3/4 tank of gas and it was 434 lbs. So maybe the 6.52kg/mm spring will work after all.
trident00
Nov 1, 2010 05:37 PM
inderocker
Jun 7, 2010 12:22 AM
krongsak
Apr 20, 2010 06:42 PM
seroj
Mar 17, 2010 11:17 AM
inderocker
Jun 16, 2009 10:46 AM
