No High Beam???
Old Aug 28, 2006 | 09:35 PM
dan's Avatar
dan
dan
No High Beam???
Guys/Gals,
Riding along casually the other night when all of a sudden my high beam just cut out but low beam still worked, thinking it was the bulb I changed it the next day and the same thing it worked for all of 5 seconds, so I took the switch block apart thinking it was dirty contacts and cleaned all contacts thoroughly and still no high beam, does anyone have any suggestions as the next step will be to take it to a bike shop
Thanks in advance
Dan
Old Aug 29, 2006 | 04:55 AM
99Hawk's Avatar
99Hawk
Dan
Have you used your multi-meter to check out the headlight socket? (engine off and engine on)...
The headlight circuit is rather simple.
I wonder if you have a reg/rect just starting to act up...
Old Aug 29, 2006 | 02:45 PM
dan's Avatar
dan
dan
Thank you 99 Hawk, because I am also noticing the lights get noticably dimmer when I apply the brakes or put the indicators on, I will keep and eye over the coming weeks
Cheers
Dan
Old Aug 29, 2006 | 04:00 PM
Oooh, doesn't sound good. Possibly another R/R failure? Check voltage at battery with bike off and with bike running. Bike off should be around 13VDC, and running about 14.5VDC.
Old Dec 19, 2006 | 08:39 PM
iamanonymous's Avatar
iamanonymous is on a distinguished road
i have this exact same problem, but now it blows low beams too. started blowing igh beams last week. i have replaced 3 bulbs in four days....ideas? does this mean the rr is crap? also my gauges and headlights will go from bright to dim at random times for random intervals. bike runs perfect tho. help. sorry to resurrect thread, but i use search functions. sue me. :-D
Old Dec 19, 2006 | 08:43 PM
Good on ya for using the Search feature!!! Yeah, classic sign of failed R/R, sorry to say.
Old Dec 26, 2006 | 04:18 PM
got a replacement. problem solved!
Old Dec 27, 2006 | 11:25 AM
Radiaoktiv's Avatar
Radiaoktiv is on a distinguished road
did it work out for you?
problem solved?
Old Dec 27, 2006 | 12:58 PM
Thumper's Avatar
Guys replace the batteries often in the SuperHawk or risk the dreaded rr failure. I have decided to just replace my every three years regardless if it is having any issues or not. and by all means if your rr doesn't have a heat sink on it, put one on it soon.
Old Dec 30, 2006 | 05:13 PM
problem solved?
everything is cool, thanks. prop for u=+1
Old Dec 30, 2006 | 08:04 PM
Dave Wicks's Avatar
Dave Wicks is on a distinguished road
Duh question??
How do you put a heat sink on the rectifier??
Dave
Old Dec 31, 2006 | 08:21 PM
shayne's Avatar
Later model units (2001 onwards I think) have the heat sink built in.
You can fit one to an early unit by using special stuff to glue it on with, that helps transfer the heat. A computer component or electronics store should be able to help you out with what you need for the job. I have not done it myself as I had a later model RR, but I have seen it done. The guy also added a small fan to it to cool it down, but I think this is overkill. I am not aware of any later units with just heats sinks failing.
Tebs
Jun 9, 2013 07:31 PM
MikeMcW
May 15, 2012 09:48 PM
uchi
May 12, 2011 03:32 PM
lazn
Jan 9, 2009 08:27 AM
