NO ENGINE BREAKING AND A LOUD TICKING WHEN SHUT OFF
Old Mar 17, 2009 | 01:52 PM
seb421's Avatar
ukbiker.me
seb421 is on a distinguished road
Exclamation NO ENGINE BREAKING AND A LOUD TICKING WHEN SHUT OFF
I Recently buggerd up the timing when i did the CCT job my self
had to get a mobile mechanic out, he was ace took the bike away and braught it back day after timing now seems to be spot on but he said i may have damaged the valves when i rode it with the timing slighty out, as it felt like it droped onto one cyclnder and was horrible to ride.
it feels like there isnt as much compresion and tourqe as there used to be, and when i sut off there appears to be no engine breaking at all. any idea what causes this? is it a valve/vales's
he said he will srip the engine and look at it for 200 pounds, which i think is prity awasome.
any ideas people?
thanks
(bikes done 15,000 miles)
Old Mar 17, 2009 | 02:06 PM
tosh23's Avatar
tosh23 is on a distinguished road
snap his hand off
Old Mar 17, 2009 | 02:09 PM
reaper's Avatar
You can save some money by removing the cylinder head yourself. If you have a paper copy of the FSM it explains how to remove the head. If you do not have the paper FSM, it is available for download on the site. The FSM shows step-by-step the disassembly process. I helped another member, tromo1, remove the rear cylinder head on his bike when he had a similar problem like yours. The exhaust valves got slightly bent, but enough to need replacement. No special tools required other than a 1/2" drive to loosen the cylinder bolts.
Good Luck
Old Mar 17, 2009 | 04:07 PM
HondaJim's Avatar
Will drum for BBQ
HondaJim is on a distinguished road
How much to do a compression check? If you've got a bent valve it should show up that way.
Old Mar 17, 2009 | 04:15 PM
mdbuehler's Avatar
mdbuehler
The compression check tool is pretty cheap, most auto stores have them. You can also use that adapter with an air compressor to do a leak down test to let you know which valves are causing the problem too. Just put the piston at TDC, pressurize it and the listen to your exhaust / carb for the sound of the air going by. Lets you know if its intake or exhaust valves. Listen to the crank breather (or your oil fill cap hole) for bad rings / head gasket.
Old Mar 17, 2009 | 06:15 PM
Hotbrakes's Avatar
No engine braking? Did he install a slipper clutch?
Old Mar 17, 2009 | 06:32 PM
DO A COMPRESSION TEST!
It's simple if you know how to replace spark plugs.
1. Remove both plugs. Ground plug wires to the engine or remove ignition fuse to prevent spark.
2. Insert compression gauge into plug hole hand tight.
3. Crank engine for 5 compression strokes. (watch needle on gauge jump 5 times)
4. Repeat for other cylinder.
5. Compression should be 164 psi/11.5 kilograms per centimeter. (per Honda service manual)
If a valve is bent you will have quite a bit below spec on that cylinder.
Old Mar 18, 2009 | 04:35 AM
Fozzy Bear's Avatar
Fozzy Bear is on a distinguished road
But how much will he charge to put it back together?
Old Mar 18, 2009 | 04:54 AM
gboezio's Avatar
Leakdown test will rule out bad cam phasing, if it checks ok check the cam alignment, if it fails, listen where it goes out. The ticking sound is a nasty clue that a valve is out of wack.
A compression test will work too but a bad cam phasing will drop comp test.
milo2
Mar 30, 2012 02:44 PM
98VTRrider
Aug 1, 2010 07:12 PM
VTS
Dec 23, 2009 07:58 AM
avramd
Oct 22, 2009 08:42 AM
Chuey
Jun 16, 2007 09:44 PM
