NGK iridium spark plugs
Old Feb 1, 2006 | 10:28 AM
Les's Avatar
Les
Les
NGK USA's website calls out an iridium spark plug for my 98 Super Hawk but I BELIEVE the manual calls out something else. I think its a platinum plug. What are you guys running?
Old Feb 1, 2006 | 12:34 PM
Loco's Avatar
Loco
Stock ones should be Iridium, but I don't feel like dropping $9-15 per plug, thanks. I am running Champion plugs I got at WalMart for $2.99 and there is absolutely no difference IMHO.
Old Feb 1, 2006 | 04:05 PM
jschmidt's Avatar
jschmidt
Iridium plugs offer nothing over platinum plugs.
Old Feb 1, 2006 | 09:08 PM
Les's Avatar
Les
Les
Re: NGK iridium spark plugs
DPR9EIX-9 is what NGK USA calls out. DPR9EVX-9 is an NGK of the same type except it has a VX which is a high performance platinum plug. I'll go with the iridiums and let you know if I notice any change in performance.
Old Feb 3, 2006 | 04:22 PM
mikecronis's Avatar
mikecronis
Iridium plugs last longer but have less conductivity.
Copper has the most, then gold, then platinum, then iridium for conductivity. Longevity is the reverse order due to heat and/or corrosion.
Note* There will be no immediate noticable gains with either plug. After 40,000 miles, the iridium plug will be still strong, the copper one probably worn-out and its gap enlarged undesirably. Gas milage will be good with the iridium or platinum plug better than the copper and slightly better than the gold one after several thousand miles due to it wearing out.
Old Feb 16, 2006 | 12:11 PM
Les's Avatar
Les
Les
I put the NGK Iridium plugs in that NGK recommends and I put a new air filter in at the same time as the plugs. I don't notice nor did I expect any change in performance and that is a good thing. BUT I do get about 4 mpg more now! I got 44.6 mpg on the last tank full. The bike only has 8k on it so I don't think the air filter could have been that dirty but I do live in a very dusty environment, Tucson AZ.
Old Mar 7, 2006 | 11:12 AM
Turbodgixxer's Avatar
Turbodgixxer
I use the iridium's as that's what I run in all my bikes. The 5545 is the stock number, and can be had at nearly any local parts store, in 1 to 2 days. Just watch out if they want to sell you ten instead of 2 or 4. I over maintain my stuff, so I don't mind the boxes of 4. If you do, see if someone else wants to buy a pair with you. I get charged $8.25, but i think they are cheaper if you go to www.ngk.com
Old Apr 1, 2006 | 11:50 PM
tony.wilde1's Avatar
tony.wilde1
be thankful we dont own a new ducati!!!their plugs are surface erosion and are £50 each!!!!about $80!!eeeeeeek!
Old Jul 26, 2007 | 04:59 PM
Alpar's Avatar
Alpar is on a distinguished road
Do you guys know what the gap is supposed to be for the spark plugs???? I can't find that info anywhere.
Old Jul 26, 2007 | 05:19 PM
drew_c14's Avatar
check one of the other 83 threads in which you asked this question and you'll find my answer
Old Jul 26, 2007 | 07:50 PM
NovaWildcat08's Avatar
NovaWildcat08
$80? Try $100.
You Brits tend to forget how much our dollar sucks lately.
Old Jul 26, 2007 | 07:59 PM
Alpar's Avatar
haha... sorry !!! i just copied and pasted for a bunch of threads that i was reading through
Old Jul 26, 2007 | 10:22 PM
redman's Avatar
I bought my oil filter (Fram), oil (Mobil Racing 4T) 6 qt case, and Champion supermax or somesuch ridiculousness, and new coolant, and drain pans, and recycled oil jug, and funnel....at WalMart for less than 100bux. My local auto parts didn't have any of that stuff but WallMart did???? Go figger.
God Bless AmerKa.
BTW, I also threw in some RedLine WaterWetter....it runs cooler now...really.
hondavtr1000sp2
Nov 17, 2014 09:07 PM
jeephawk
Mar 28, 2013 07:43 PM
justinity
Oct 10, 2010 10:45 AM
Hawkrider
Jun 16, 2009 07:03 AM
mikstr
Oct 19, 2006 09:57 PM
