Neutral switch problems
Old May 31, 2010 | 10:42 PM
996Riders's Avatar
996Riders is on a distinguished road
New to the forum, heres a problem Im having. When I first start the bike in the morning with it in neutral and stand down the neutral light will be illuminated while engine still cool, BUT then once the bike gets warmed up the bike will no longer have the neutral light illuminated when its in neutral unless the bike is leaning to the left like way left
Old May 31, 2010 | 10:43 PM
Have you tried pulling the bulb and cleaning the contacts and\or checking to see if it is fully seated in the plug?
Old May 31, 2010 | 10:55 PM
+1 - Yup, if it continues to run with the kick stand down and the neutral light out, then it's not the switch.
Old May 31, 2010 | 11:01 PM
996Riders's Avatar
NO the bike wont stay on with the stand down after warm up. I just dont understand why it only does it after warm up and but also the bike AFTER WARM UP the light will illuminate if i lean the bike to the left.>?
Old May 31, 2010 | 11:10 PM
Most likely because the switch is on the left side of the bike? And since the neutral switch is either gummed up or faulty, it won't run on the sidestand, as the clutch/sidestand switch in conjunction with the faulty switch will kill the bike, thinking it's in gear...
Old May 31, 2010 | 11:21 PM
996Riders's Avatar
Thanks
Old Jun 1, 2010 | 09:13 AM
nekkid's Avatar
Pull the wired connector from the switch straight out of the lower left side of the engine case. Shoot it with elec. contact cleaner, plug it back in. Should be OK after that.
skokievtr
Sep 8, 2014 05:07 PM
Hayai
Dec 11, 2011 05:23 PM
inderocker
Apr 26, 2010 06:44 PM
moto-rama
Sep 21, 2009 05:36 AM
djkaoscc
Aug 27, 2008 10:05 AM
