Need help with valve clearance RT and FT position
Old Nov 11, 2012 | 09:37 AM
lgaszynski's Avatar
lgaszynski is on a distinguished road
Hi
I start to a little rebuild my VTR1000F from 98 EU version.
I take off the engine and check the cam chain and other things
So i want to check the valve clearance
I take the caps and rotate the pistons to FT position and here is a question
how to get a right position, the hole mark must be between the R(F) and T symbol or directly on line(-) symbol whit is before RT and FT mark
If I rotate to line position (there is line to line in hole) the cam symbols FI FE are't in line position. There are well when i operate a little more than FT symbol and between R and T for the rear cylinder.
In my manual a see in the hole that is operate between the RT and FT symbols but in manual for VTR SP there is clearly write that line in hole must be face to line before RT and FT symbols
Please help me with this problem
The photos from the forum
I get two photo the ft mark and FT line mark
Which is correct?
Sorry for my English but i write from Poland
Attached Thumbnails Need help with valve clearance RT and FT position-ft-mark.jpg   Need help with valve clearance RT and FT position-ft-line-mark.jpg
Old Nov 11, 2012 | 09:42 AM
saige's Avatar
the boss
if i understand what you are saying,you are going to line it up with the line,not the letters.
that should put it exactly where you need to be.
Old Nov 11, 2012 | 09:45 AM
lgaszynski's Avatar
which is correct line in timing hole with line or letters (between the letters RT or FT) on flywheel ?
because the front cylinder cam is wrong line with both situation, i want to correct this.
Old Nov 11, 2012 | 09:53 AM
aja's Avatar
aja
If you already have the valve covers off and can see the cams, line the FE and FI (or RE RI) marks up with the head surface. Front cams will point away from each other at 45 degree angles, the rear will point towards each other at the same angle. Do it this way and you do not have to worry about getting the FT mark perfect.
Old Nov 11, 2012 | 10:04 AM
lgaszynski's Avatar
I do this and for the front cylinder the mark is after the FT symbol and for rear in the middle of RT symbols
i want take of the heads and install new cam chain so i need to make a perfect regulations and timing
p.s how to check the cam chain i have about 12mm to end the cam tensioners
Old Nov 11, 2012 | 10:10 AM
The difference between the SP1\2 & a VTR is the SP1\2 is a gear driven cam and the VTR is chain drive.
That is why the SP1\2 must be dead on and the VTR might not exactly line up.
Old Nov 11, 2012 | 10:19 AM
saige's Avatar
the boss
if you are doing the cct's,only do one head at a time.
for the front head,the marking is FT
for the rear head,the marking is RT
on the cam it self,it will have FE and FI or RE and RI
the front cam is FE and FI
the rear is RE and RI
make sure to follow instructions on the cct thread,zip tie the chain so you will not lose timing.
https://www.superhawkforum.com/forum...pe-ccts-11275/
the marking in the cover does not need to be exact,but close to it to make sure you are where you need to be.
Old Nov 11, 2012 | 10:28 AM
lgaszynski's Avatar
Yes i know that Sp is on gear driven cam
So any post told me that it's not important that the mark is on line or on symbols
i need to take a decision when i get everything together how to do the timing regulations
The pistons going up and take the up death point on line and after te FT or RT mark is going down so I need set the flywheel on line or Symbols and it's not important where?
Old Nov 11, 2012 | 10:31 AM
saige's Avatar
the boss
as long as you can see the mark and its close to the line,you will be good.
but just make sure you have the correct mark for the correct head.
reaper
Feb 23, 2009 11:39 AM
edgarbaker
May 11, 2008 02:39 PM
inderocker
Feb 13, 2008 02:48 AM
ghopki1
Dec 28, 2007 11:31 AM
mikenap
Jun 7, 2006 07:01 PM
