Need help with clutch questions....98 superhawk
Old Mar 25, 2009 | 07:43 AM
SloatsburgSuperhawk's Avatar
SloatsburgSuperhawk is on a distinguished road
Question Need help with clutch questions....98 superhawk
i have a 98 superhwak and it is starting to slip in 4th and 5th at high rpms....... rpms jump up and accel. doesnt really... any idea whta it could be only has 6k miles on it.........how hard is it to change the clutch and does anybody have instructions on doing it??? thanks kevin
Old Mar 25, 2009 | 09:11 AM
swordfish's Avatar
2 questions: what oil are you using? and are you, or was the previous owner stunting it?
Old Mar 25, 2009 | 09:30 AM
The reason swordfish asks is that if you use an oil with "friction modifiers" that can create these kinds of issues.
Old Mar 25, 2009 | 12:27 PM
HondaJim's Avatar
Will drum for BBQ
HondaJim is on a distinguished road
and 6k is way early for a clutch with the right oil and no abuse.
Old Mar 25, 2009 | 08:59 PM
nath981's Avatar
do you know what oils have modifiers that negatively affect the clutch or how does one find this info?
thanks, Nathan
Old Mar 25, 2009 | 10:15 PM
Molybdenum is probably the most common friction reducer to look out for.
Old Mar 26, 2009 | 02:17 AM
Wicky's Avatar
http://www.sportrider.com/tech/146_0308_oil/index.html
Oils Well That Ends Well, Part 1
Part One: What is motor oil really made of?
By Don Smith
Editor's Note: This is Part One of a special Sport Rider comparison test, where we unlock the mysteries and debunk some of the myths of motor oil. We examine just what goes into motor oil, why those ingredients are there and what it means for your engine. In the next issue, Part Two will feature a scientific analysis of all major motorcycle-specific motor oils, plus a wear and dyno test of specific oils to determine whether there is a power difference.
From my VTR manual : SAE 10W40 - API grade SE, SF or SG motor oil
http://www.vfrworld.com/tex_vfr/tech/oil.htm
thanks, Nathan
Old Mar 26, 2009 | 07:23 AM
i dont think the previous owner stunted it and im using maxima performance 10w30
Old Mar 26, 2009 | 08:02 AM
nothing's Avatar
ride it out
does anyone just use GN4?
Old Mar 26, 2009 | 10:12 AM
HondaJim's Avatar
Will drum for BBQ
Me. Red Cap.
Old Mar 26, 2009 | 10:28 AM
swordfish's Avatar
I only know so oils that don't have the modifiers. not the ones that do. I know mobil 1 is my choice. GN4 is good. spectro gold is ok. motul is ok but gets dirty really fast. same for rotella.
chadnol10
Mar 22, 2011 12:56 PM
Irish0170
Mar 1, 2011 06:25 PM
cagedruss
Jun 20, 2008 06:19 PM
mill7163
May 7, 2008 04:01 AM
kevinmeller
Mar 4, 2008 04:26 PM
