Mototec Undertail
Mototec Undertail
Anybody know of anyone whose had a Mototec undertail?
I was curious about build quality, their color matching the factory color, and ease of install.
When you use one of these, do you usually get a rear grabber too?
Thanks,
Terr
Thanks,
Terr
Re: Mototec Undertail
I have one.
Excellent paint match.
pictures here and further down the page are links to where I bought it & other info.
installation instructions sucked.
I'll try to take some pics tonight from the inside of the seat area so you can see how much inner fender I had to cut.
https://www.superhawkforum.com/viewtopic.php?t=1917
A hugger (rear fender) is not required if you leave the stock "flap" in place to keep dirt, mud, water off the rear shock.
I did add a Pyramid carbon hugger & removed the mud flap near the rear shock.
Sorry for the confusion.
Still want pics of how much inner fender I removed to get the Mototec unteratil to fit?
http://ca.pg.photos.yahoo.com/ph/vtr...00_w/my_photos
that is a mototek undertail, hugger and blinkers.
Pics from the inside showing cutaway part.
I used a solder gun with a flattened tip to melt thru the black plastic instead of cutting or sawing it. It made less of a mess and was easy to control the 'cut'
In hindsight I could have cut less & had it fit.
