Master cylinder rebuild Issue
Old Nov 1, 2020 | 02:09 PM
ACE VenTRa's Avatar
Is anyone familiar with a Nissin 3/4 master cylinder? I suspect it's off of a 600RR, it's an axial with remote reservoir and I can't seem to find a rebuild kit for it. Alternatively, does anyone know in which application it may have been used?
Thx
AV
Old Nov 2, 2020 | 05:37 AM
Unlikely from a cbr600rr. "04-'06 were integrated reservoir axial, '07 on were radial. Could be wrong, but there wasn't a 600rr pre '04 and they didn't have remote reservoirs.
Old Nov 2, 2020 | 07:23 AM
I'll check my 00~01 VTR1000SP1 & 02~06 SP2 MC for their sizes & LYK...
Did you check the VTR brake component compatibility list?
Old Nov 2, 2020 | 11:13 AM
ACE VenTRa's Avatar
Nope, but I figured it out. It can be from either a 929 or and rc51.
Solved
AV
Old Nov 2, 2020 | 11:24 AM
Solved
AV
I thought the earlier years were 3/4 and the later years 5/8 can you verify that or I can go look I have them both
Taken earlier
Old Nov 2, 2020 | 12:21 PM
ACE VenTRa's Avatar
Well, the 929 had a two year production run. So early I suppose
AV
Old Nov 2, 2020 | 02:45 PM
I meant the RC51 / rvt / s p 1 / s p 2
Old Nov 6, 2020 | 05:02 PM
ACE VenTRa's Avatar
Not a clue really, all ***** sells a kit though. It's just disturbingly difficult to find that info reliably. What I ended up doing was finding a 929 master on ebay and zooming into the photo to see the casting marks. Once I confirmed that I found the part number and it crossed over to RC51 as well.
AV
Old Nov 7, 2020 | 05:39 AM
Have you looked at this?
https://www.superhawkforum.com/forum...ke-mods-13176/
Old Nov 7, 2020 | 05:48 AM
ACE VenTRa's Avatar
Many times...but If it shows what bikes have used 3/4 mc...I've not seen it.
Av
Old Nov 7, 2020 | 01:52 PM
19mm is ​​​​​​ 3/4” (.748”)
Old Nov 7, 2020 | 01:56 PM
ACE VenTRa's Avatar
Nope.... .750" is 3/4". That's why the master is cast with the number "3/4" and not 19mm. Interchangeable? Sure, probably. Was I aware that .748 is almost 3/4, Yes, but none of that helps me find a rebuild kit. Only the application does, which is why...I asked if anyone else was familiar with the application.
AV
IL8APEX
Jun 24, 2016 02:45 PM
FTL900
Aug 28, 2013 05:54 PM
102dals
Aug 17, 2012 04:25 PM
Killemall
Nov 7, 2007 10:05 PM
davidhartley
Aug 4, 2005 06:47 AM
