Leakdown tester issues
Old Feb 24, 2012 | 09:13 AM
So I bought a leakdown tester but it has only automotive adapters, does anyone know a good place to get motorcycle adapters?
I am hoping these work Amazon.com: Equus 3618 Adapters for Compression Tester: Automotive
Old Feb 24, 2012 | 09:44 AM
Those will probably work. The simple compression test gauge that I bought had a set of those and one of them fit...
Old Feb 24, 2012 | 09:56 AM
If your handy... make one from a plug.. or you can buy the 12mm adapter from a snap on tool truck.
Old Feb 24, 2012 | 10:00 AM
thetophatflash's Avatar
If your handy... make one from a plug.. or you can buy the 10mm adapter from a snap on tool truck.
+1, Made mine out of a spark plug. First did it in '86 when I made my tester.
Old Feb 24, 2012 | 10:28 AM
I am really trying to avoid making my own since I dont want to create more weak links in my leakdown test. I am willing to buy an adapter but just cant find one.
Old Feb 24, 2012 | 09:30 PM
EEPV306A, Adaptor, Compression Gauge, Motorcycle, M12 x 1.25
$36 any Snap on tool truck or order it on line. The QR fitting may or may not fit your gauge set... most gauges , the female QR is replaceable.. should be able to unscrew what you have and screw on one that matches the Snap On part.
fred
May 4, 2011 12:33 PM
ericb269
Apr 5, 2009 03:08 PM
digitaledge
Jun 1, 2008 07:18 PM
crazybrit
Dec 14, 2007 08:28 PM
ali_squidz
May 4, 2007 08:48 PM
