Is it Jetting?
Old Sep 11, 2008 | 07:13 AM
Little_Horse's Avatar
2nd mouse gets the cheese
Is it Jetting?
ok so I have this weird rpm issue. When I ride the bike a feel a little pulse or what seems to be a miss, real slight at about 3500 rpm so today I held it steady in nuetral at this rpm and sure enough it would ever 1 to 2 seconds drop 300 rpms or so then 1 sec or so later pop back up to 3500 and it would continue doing this as long as I held it there. I have tried all sorts of different jetting but no matter which direction I go the problem still is there. My bike is stock except for a BMC air filter. I have a dynojet kit, stock mains, needles on the sixth slot 45 pilots idle screws 2 turns out. Other than the random up and down it pulls real well under harder acceleration just bumps when riding in traffic.
Old Sep 11, 2008 | 10:59 AM
RK1's Avatar
RK1
I doubt it is the jetting.
Were it my bike I'd turn out the pilot screws to 2.5 turns which is the advice of both Honda and Dynojet, and I'd scrap the BMC air filter for the Honda OEM filter. Do those 2 things and I'd bet it runs fine.
Also realize throttle position for 3500 rpm in neutral is different than throttle position in gear on the road. Also 3500 rpm will be a different throttle position in each gear.
Old Sep 11, 2008 | 11:29 AM
PUSHrod's Avatar
Are the carbs in balance?
Old Sep 11, 2008 | 12:13 PM
yeah I just balanced them the other day to check if that would solve it. At 2 1/2 turns it was too rich and wanted to die, also fouled my plugs at 2 turns it idles really well. It does the stumble in both nuetral and in the gears doesn't matter, although at 60 + miles an hour you can't feel it anymore. I still need to check my spark plug gap, the shop fubared my bike a while back and I am still trying to sort all the issues out.
Old Sep 11, 2008 | 12:36 PM
RK1's Avatar
RK1
Suit yourself. The stock bike runs pretty well with 2 and 1/2 turns out on the pilot screws with the OEM air filter. If I installed an after market air filter and it ran rich, meaning LESS air flow with the aftermarket filter, I'd think about losing the aftermarket filter.
Old Sep 11, 2008 | 12:40 PM
well Im just stating what it seemed like to me, I may try 2 1/2 turns again considering it was out of ballance before and that may have been what made it run poorly at 2 1/2 turns out. I will try it again. Also I have been running the BMC air filter since I owned the bike and it never used to do this. I would like to keep using it considering the cost of replacing a stock one vs cleaning the BMC. So I take you are leaning on the fact my bike has a lean stumble which can be fixed by a richer idle screw setting?
Old Sep 11, 2008 | 01:27 PM
RK1's Avatar
RK1
I just don't see how you could be running rich at 2.5 turns out with everything stock except the filter, unless the filter is more restrictive than the stock one.
I tried tuning my bike to the BMC race filter when I put my cans on and couldn't get it to run right. The idle was eratic, when I'd rev it in neutral it would hesitate and hunt, all fluffy and weird. Same or similar to what you are describing.
Ran fine over 4000 rpm under load.
I think it had more to do with flow characteristics than rich or lean, but when I went back to the stock filter I got it running better than ever.
Other folks on the forum say thay cured the low rpm weirdness with aftermarket filters by going to #48 pilot jets, which I didn't try, but that argues for lean beforehand, not rich.
If you could borrow another VTR riders air filter for a ten minute ride it might tell you something. I just know folks who try to tune the VTR to the K&N or BMC filters seem to have a lot more trouble getting it right than folks who stay with the stock filter.
Old Sep 11, 2008 | 01:45 PM
I agree on the filter reasoning, I will borrow a filter and see as well. Just seems strange I don't remeber it doing this a yr ago I have never had a stock filter in it for very long. I did try one a while back to fix a different problem turned out my coils were bad. But since I put new coils in it I have't tried a stock filter to see if it will fix this problem though, so between a stock filter and adjusting the mix screws I have a few things to try thanks, I will let you know how it goes.
Old Sep 29, 2008 | 06:52 AM
Well as an update here, turns out the shop I took it too screwed up my cam timing. This weekend I put apes on and messed up the front cylinder so I had to retime the cams up front and now my bike is running alot better than before. My guess is when the checked my vavles and replaced a shim up there some careless mechaninc had it one tooth off. Its not like it was running horrible just nueterd a little, now it rips more like it did before, and to think I spent hours on jetting.
Old Sep 29, 2008 | 08:40 AM
Springbubba's Avatar
Uhhhhh..huh.huh..Member..
Old Nov 18, 2008 | 12:16 AM
wcavasos's Avatar
wcavasos is on a distinguished road
hey cornandp, I have this hesitation at between 2000 and 2500 rpms I hear and feel it in and out of gear (just sitting there parked, or riding as well. It sounds disturbing and kind of scary, I thought at first that the forward cam chain tensioner was the culprit, so I changed it. I did feel a very large horsepower gain, I made sure not to jump timing from where the cam chain rested on the intake and exhaust cam gears by zip tieing the chain to them. So the timing wasn't off just loose and sloppy (I think). But I still get the cough and the immediate slight hesitation. I am kind of irritated that I haven't figured it out on my own yet because... well I guess I thought I was a better mech than im turning out to be, any more ideas? You sound like the kind of guy who knows what he's talking about, thanks in advance for any thoughts. And anyone else can chime in, don't be shy
Old Nov 18, 2008 | 12:34 AM
wcavasos's Avatar
oh yah this sound is kind of like a chunk, chunk, sound and is only once imediately preceding the hesitition, never hear it above 3000 rpms or below 2000 rpms though. this will repeat itself if the bike is held between those rpms but is not rythmatic.
Old Nov 18, 2008 | 07:34 AM
well, I can at least say don't give up, I finally found my last problem that I thought was a slight lean miss actually turned out being an unbalanced rear wheel, so the moral of the story is just keep plugging away until you find the problem. On that note when you say "chunk" is it just a sound, or a movement chunk or both. You said when sitting there so I am assuming also in nuetral, if it does then you can move on to just motor and transmission. How does it shift? How many miles on your bike, and have the valves been checked? See most likely your chunk is something loose, because this is not a characteristic hawk thing. So I might not be able to help, but the more info, the easier it is for some of the brilliant people on the forum to help you narrow it down. Keep us informed.
Old Nov 18, 2008 | 01:22 PM
wcavasos's Avatar
well yes I did mean nuetral, and chunk as a sound and a mechanical collision, at least it feels like it, seems to me like its coming from the forward cylinder, but it is hard to isolate. I have inspected the forward cyl. valvetrain and there is no damage or wear, everything looks brand new. I have also inspected the bottom end, pulled the oil pan and found no foreign objects, everything that I can see ( crank, rods, oil pickup and pump, lower portion of the timing chains and guides, some of the clutch plates, and trans gears) are showing no signs of damage due to not being adjusted properly. I am beginning to believe that I have been mistaken this whole time about the sound that I have been hearing. Can it just be some coughs spit back from poorly sync'd carbs. Oh yah, my bike is a '98 with 58,000 miles, runs very strong otherwise with no other problems. Thats pretty much all the info that I have. Thanks for your thoughts
Old Nov 18, 2008 | 02:59 PM
What about it backfiring back through the carbs, that sounds and feels kinda like a chunk? Other than checking compression I don't know enough to help much more than that. You might start a new thread so more people will notice your problem and give advice. Just my 2c's.
I looked back through your posts, I am definitley leaning towards it backfiring through the carbs, although unless the sync is really bad I don't think it would cause it to do this regularly, it might be time to clean out the old carbs.
Galaxieman
May 7, 2007 06:45 PM
FRANKSVTR
Mar 31, 2007 05:12 PM
cliby
Mar 30, 2007 11:57 PM
redlinetech
Mar 16, 2007 04:34 PM
Shawn Torpey
Mar 9, 2007 08:54 PM
